Mk2 polo question
Hi,
As some of you will know, I went into the back of someone and mashed up the front end of my Mk2 Breadvan. Anyway, I've just ordered the needed parts to get it back on the road:
Front Bumper (from Beevers panels)
Front Cross member (from Beevers panels)
Lower front panel (from Beevers panels)
Bonnett (from Scrapyard)
Front Grill (from Beevers panels)
Has anyone ever fitted the crossmember and Front panel? If so, is it a hard job and any tips you could give me?
Thanks in advance!
  • Views 995
I mentioned this thread before maybe didn't give right link? post 159... give Kat a PM
http://www.clubpolo.co.uk/forum/index.php?...8152&st=150
Other than that sorry?
Edited by MacColl
can you weld ?
its not a super hard job for someone thats done bodywork , but its not bolt on or anything easy
you would need to drill out or grind away all spot welds and remove the old panel ...clean up the edges and apply weld thru primer
make some holes in the new panel where the old one was spot welded
fit the panel on with a few self tapers and then fit the bonnet and wings ...ajust it until its all lined up sweet , then make welds in the same places as the orignal ones, grind the welds and prime /seal/paint
cover the windscreen as grinder sparks burn into it
