9N - Leaves stuck under windscreen
Hi,
This is my first post in years, so hi everybody!
I was giving my car a really good clean this weekend, did all the usual under the bonnet tidying etc. and I noticed a bit of a trap underneath the windscreen behind the front struts. There are lots of leaves and general rubbish trapped in this area and I can't get them all out, the space seems to be a drain for water off the windscreen but nothing bigger than water seems to be able to empty out. I am a bit worried this could be a potential rust trap (mk2/3 battery tray styleee)
An image of the area (when I got the car i.e. clean) is attached.....
Has anybody else experience this or managed to find a way to clear it out?
Cheers!
  • Views 907
you can remove the scuttle tray and clean it out if you need to.
I wouldnt really worry to much mate, as Panda said you can remove it if you feel so strongly.
Thanks for the replies! Is it a simple job to remove it panda?
yeah, I can't remember exactly how I did mine, but it's really easy. If you're struggling, go buy a haynes.
