MKIIF Polo - Lowering
Hey ladies and gentlemen... I'm replacing the springs (dropping it 40mm) the back was no problem got that sorted... but the front is puzzling me! do i need to remove the driveshaft and hub etc? or is there a another way of doing it?
Cheers in advance! 8-)
  • Replies 13
  • Views 1.7k
Any one help us out? :)
I Find it abit of a pain, you need to remove the drive shaft Nut, Track rod end, the nut holding the lower arm and anti roll bar of. It sounds simple but the bolts are usually pain in the arse cause everthings rusty. Get a Haynes Manuel and give yourself a couple of days to do it.
soak everything in wd40
Remove drive shaft nut
Remove top nut ( I find easier)
Remove track Rod end
Remove bolt and nut holding anti roll bar in and lower arm (wishbone bit).
Theres a very basic plan to remove the strut to get the spring in, theres more to it than that but it give you a ruff idea.
Also you could try searching matey, because its been asked lots, but your a noob so its ok :p, a thread below which explains it all for you.
http://www.clubpolo.co.uk/forum/index.php?...ing+mark3+guide
Tommy.
Edited by PoloTommy
Cheers Tommy.... thats what i thought... Will i need to compress the springs?
Amy :)
Amy :)
Well I have managed to do it without using spring compressors, but in theory you should. I've lowered mine 40mm without spring compressors, so you should be ok! :-) I feel helpfull for once lol
i have a mk2 but its the same idea
i took pretty much everything off and i highly suggest spring compressors :)
good luck
Alex
good luck
Alex
I had to take my car into the garage I work and burn some bolts off, was a nightmare. Prox, maybe because you used lower springs didn't you? I know you defiantly should use them, but I've got away without using them...
kool thanks guys! iv got some spring compressers anyway so ill use em :p ill let you know how i get on... i want her lower... but money and time is stoping me! so the 40mm will do for now! haha... better than her being on stalks! eps now iv got my 13" Allycats on low profile tyres haha
Dreading when I have to do this by the sounds of it lol... don't think I got any spring compressors but my old man has some clamps which might work :).
not intending to live long then? :lol:
I've seen a proper spring compressor fly off and leave a hefty dent in a breeze block, imagine what would happen if something like a G-clamp slipped...
while this job is possible without them to a degree a set of spring compressors is advisable.
Amy: With the driveshaft nut you may need a power/braker bar and a 32mm socket (found an impact socket works better). You may also find that the top caps sit a bit higher.
You dont need to compress the springs with anyting other than the cars weight - simply undo the top mounts (both the bolt and castle nut underneath it) before you jack the car up.
Lol DAMMM! Good job I not tried to fit a lowering kit eh ;D.
Thats a much easier way, no risk of taking off a testicle if a spring compressor slips. :lol: Should make replacing my top mounts a lot bloody faster & easier.
Thats tomorrows job then, wasnt gonna do it till next week as my compressors have gone walkies.
Heh where's the fun in that? I thought it was "scene" to go as low as possible, so surely slashing a ball off would make the other hang lower..?
PS: Loving you are car btw Cymro, wanna do the lights on mine too :).
