Sideways Into a Kerb
Ok, got my car back last tuesday from the garage, driving home i was driving normaly (very rare i do that :lol: ) going round a corner on a country road the back end slipped out very agressivly and smashed into the Kerb, went back to retrive the rest of my wheel to find alot on oil/deisel on the road!
The hit to the kerb shattered the rear 13 VW alloy i had
Now i have some 16v 6n wheels on the car i bought yesterday. but i can hear a slight wobbling noise coming from that wheel area, anyone hav a idea what this maybe? damaged wheel bearing?
Wheels are in mint condition, so are the tires, so that rules them out.
I cannot feel the wobble only hear it :roll:
  • Replies 21
  • Views 2.5k
thats an amazing picture! lol i would..
jack the rear wheel up, spin it and check for the noise.
if its a kind of rumble noise i would say wheels bearing mate.
check that it spins true and not buckled (hub not the wheel)
jamie
jamie
yea didnt have a helicopter handy to take a birds eye pic so i comprimised :lol:
thanks for the advice :)
was that a drawing? :o its so accurate i thought it was an areal photo! lol
when i said spin and check its true, hub not the wheel, i meant turn the wheel to see if anything buckled.. and as you say wheels are good, then any movement will be from within ;)
Macclesfield Drift woooooooop
those must be some thin ass tyres
:lol:
________________________________________________________________________-
got another question,
seems like my seatbelt locked when i hit the kerb (safty feature?)
the point its locked from is withing the side pillar area (sea beat inertia?)
how can u unlock this? thanks :)
"those must be some thin ass tyres"
standerd 13" vw alloys, which i think are like 4.5j :lol:
got some 6n vavler wheels (6j) now, probably would have stopped me if i had them in the crash :lol:
Edited by mattpolo5491
Your hub is probably fucked mate
Edited by Po*Low*
lol they really are shit, i had a similar accident but due to ice with i think the same size wheels
Edited by punkins
wider wheels dont always mean more grip due to a mk3 polo (small car) not having the weight to keep the tyre bedded to the road. or so I'm told?
whats a macclesfield drift? all i know is I'm from the town of Macclesfield haha!
surely the larger surface area is an advantage
Edited by punkins
dunno what he meant by it mate :p
never seen your gt driving around macc? I'm usualy out every day and night :lol:
got slolo writen on the back of my polo mate, ever see me giv us a honk and ul get one back :) well my cars more of a peep noise :cry:
oh and also had nixen tyres on tha back, biggest pile of shit rubber u can by today lol
You'll hope the axle's not bent,or the axle mounts,whilst replacing the..
A) Stub axle
B) Wheel bearing set
C) Rear drum
Should be fine after that,as long as the replacement wheels sit tracked and cambered the same both sides,indicating a straight axle.
I did the same in a Metro,and bent virtually everything including trailing arm and subframe.
span the hub and it doesnt seem to bad, althought it doesnt spin quietly :p
wide tyres dont give you a bigger contact patch. It may seem it but they dont.
Ad say youve probably bent your axle. Possible chassis damage too. IF your lucky, just a new stub axle bearing drum yada yada
Blamin diesel tho :lol: Maybe you were just going too fast
Edited by neil_dubgt
Ah, but the larger the surface area the lower the contact pressure, so which is best? contact area? or contact pressure?
Obviously a car with more weight or higher downforce can produce more surface pressure so can have wider tyres, but a 800kg polo?
Would be interesting to find out!
My guess would be:
Narrower tyre = more contact pressue, less contact area = steadier, more controllable loss of traction
Wider tyre = less contact pressure, more contact area = more sudden, less controllable loss of traction
someone correct me if I'm totally wrong!?? :)
Thats what i'd have said. If not, you're very bloody lucky although i'd bet somethings gotta be bent underneath.
Have you been under the car yet to have a look?
I can remember when my mate slid sideways into a kerb in his clio in the snow. Bent the n/s wheel so far under, the o/s wheel bent out. car crabbed down the road :lol:
Very rare a 1 litre 6n2's back end will go, even at speed( its pretty hard to do a breaking drift in the wet :lol:)
i went back and looked at a hugh patch of oilly mess in the road :p
think 6j wheels are about right for light polos, then agian 6n2 are alot heavier than mk1/2/3
well tested the valver wheels on the Cat and fiddle road today, seem spot on and give lots more grip :)
not hard to get the back end on any car if the roads greasy and your not ready for it
You can get the rear end out of shape in a 1.0 6n easy, any car for that matter.
Seat belt fault is that the pre tensioner has gone off, so you need a new seatbelt mate.
If thats gone off it means you hit it pretty hard, so you've probably bent the stub axle and knackerd the wheel bearing.
Also check the camber of the wheel you hit looking from directly behind, probably will have some positive camber going on!
