Removing stereo cage
Hi, does anyone know how to remove a stereo cage without using specilist tools?
  • Views 716
if its just the cage and you got the stereo out already?
all youll need is a sturdy but thin bladed flat head screw driver, once the stereos out you will see there are multiple triangular flaps that are pushed back to hold the cage in place all you need to do is straighten these out again so they are flush with the rest of the cage then it should just jiggle out.
hope this helps Malk
if not.. bend it! lol
pull it down in the top middle, again in bottom but lift it up.
pull it out and re bend it :) lol
my prefered method is as above tho :)
