ABD conversion complete
At last, thought I'd blow my own trumpet since I've had a nitemare week. I needed to remove my GT lump as it was suffering with low oil pressure, I was going to go with an abu, but I wasn't able to find one but was offered a 64,000mile 3F engine. Started the swap on Saturday morning, only to find that the 3F was infact an NZ and wouldn't run properly on the GT ECU, so out it came.
Called CMS where I bought the engine and they didn't have any other 3F's but it turned out he did have an ABD, so yesterday lunch time I went and swapped them. worked almost solid from 1pm to 7pm last nite, and again all this morning but now I've got the abd in and running, feels quite nice. I'm very happy :)
  • Replies 33
  • Views 2.8k
good lad, totally worth while conversion
Sounds like youve had fun.
No match for performance in any way compared to my current set-up,but otherwise i still think the ABD was next best. Tractable,sounded great,bullet proof and had plenty enough performance in it. I managed some impressive starts,high speeds,overtakes.. and economy. It was the best all-rounder engine in all I've tried,and it's a shame VW never put in in the pre-94 cars themselves.
I ran mine on CBR600F-X carbs,i should add.
I'm quite pleased with the results but i need to sort the ignition timing out, had to do it by guess work as i dont have a strobe and it doesn't like being cold atm.
Anyone near derby able to help with the timing, maybe someone with s strobe i can use?
failing to see how cbr600f-x carbs can be more economical than the standard GT injection setup...
Don't think anyone said that they were.
The ABD setup was what I was initially going to go for as it really did seem the best bet for the least amount of work.
Might be able to help you out by getting it set up to TDC. Our gun doesn't have advance or retard though unfortunately.
Where abouts are you and when would be a good time for me to pop around?
Yay, more fiddling over the weekend and the timing is a whole lot better. My throttle cable is very sticky though, think some moisture must have got into it while there was no enigne in the car, I will attack it with wd40 later to see if it makes it any better.
do you often get your head stuck in door frames when walking into and out of rooms?
i deleted my own replies lol
its always the same shit lol
That'd be relativity,see. I think its just as important to point out not only how big the head is,but also the door frame. That way,there's more of an understanding of the situation,and its validity from the source perspective.
Because 'It was reasonably nippy' doesnt really mean shit on its own.
But surely '...compared to what I've got now' dosent mean shit on its own? Without looking up what you have now its nothingness, except to create the assumption that you now have somthing far superior.
True to a point,but it still gives broader perspective than the solo point. I've tried comparison before,and just got abuse.
Lets have some more.
Its current state is enough to outsprint a Scirocco 2.0TSi (in metallic blue), twin exhaust TT Quattro and squirming whale tail MK1 Cossie (i didn't get to speak to the TT owner,but the other two were keen to find out how i stayed in their company).
This will obviously generate the usual ridicule,and that's fine. I know when I'm beaten,and though i kept catching the 05 plate M3 at roundabouts he had enough to pull away on the straights and I'm shamed. Or not shamed,as they're seriously fast.
But that's where i am. Some G40s (or E45s,whatever) are quicker. Great for them. Just going back to the perspective,this shows where the ABD fell - Golf MK4 1.8T territory. Not blistering by any means,but it had just enough in it to take the piss out of bigger players as long as you were in town and not on the big roads. And the car was under 770kgs with the driver in it.
Peace - for now..
I've got a timing light with full advance adjustment and I've spent enough time under a mk3 bonnet to know what I'm doing with setting the timing and idle :)
Near Ripley if thats any good for you.
I might take you up on that offer, would be usefull to have someones eye look over it all. I'll drop you a pm sometime soon to make some arrangements, but I've got flu atm so won't be going anywhere for a few days.
Peace - for now..
please save yourself, and get your car rolling roaded, i just can not get my head around anything that you say, i dont mean it in an agro way, but i just can not understand any of it.
so your saying you can outsprint a 200bhp rocco? and a TT Quattro with 225bhp?
can you see why we all frown a little? and question it?
walk on water next i reckon
how much power does your car make mikey? have you had it on a rolling road, you should bring it to the club polo RR day which I assume will be happening in january, be interesting to see.
100bhp @ 750kg is a ratio of 133 per ton
200 bhp @ 1300 is 153 per ton.
No reason why a 120bhp in a Mk2 could not beat a rocco.
From what I gathered Mikey is pushing close to 179 million bhp so he could easily beat a quattro.
But seriously. 150bhp in a Mk2 is 200bhp/ton which puts it up there with some serious cars.
Some perspective for you -
http://www.letstorquebhp.com/fwd.asp
http://www.letstorquebhp.com/rwd.asp
http://www.letstorquebhp.com/4wd.asp
Peace - for now..
What's the power:weight ratio of a 200bhp Rocco,Dan?
And the power:weight ratio of a vehicle that weighs 705kgs and has 140bhp?
Save myself? I'll leave you to see the plain obvious,then..
Interesting one Giorgio. I particularly like the figures for the 150bhp Fiesta 2.0 16v ST,and the 85bhp carb'd Citroen AX GT.
And some people still dont get it..
yes read and all understood, so your saying your rocking 140bhp? have you ever had it rolling roaded?
your evidence is all based on things written down on paper, and in your head, and nothing based on actual fact
Just a reminder kids, you cant race rolling road print outs.
So far the only person I know that can properly comment on this thread is Yoof, as he has a respectable 1/4 mile slip
this
get your car on the RR if youre so confident, or record it down a 1/4 mile. then you will have evidence :)
yeah i dont want to get into a big debate about figures etc, 1/4 mile is the only real answer
i just feel all your facts mikey are based on things on paper, and inturn you assume yours is what you say, so it has to be true
as above your patronizing quote giving the power to weight ratio, is totally flawed, have you had your car weighed? no, have you had it rolling roaded to get the bhp figure? no
so it is all just make belief
