water leaking into footwell
I've found a damp patch in my passenger footwell not yet sure where it's coming in, is this a common problem with 6n2 polos??
  • Views 901
Undo the bonnet and make sure there isn't a load of trash blocking the way to the heater vents :).
if the scuttle panel isnt blocked then pull the carpet up inc the pading and there is a few gromits under there, make sure there still water sealed as the have been known to perish
i've removed the carpet and sourced the leak, seems it only leaks when I put the climate control on.. :x
Sounds like a familiar problem for climatronic owners! Most owners tend to find that the cause is the recirculation flap not closing properly, possibly caused by the motor malfunctioning. It'd be worth checking out.
EDIT: link to old topic, from 2004, on uk-polos.net with more info: http://www.tigerstyle.co.uk/phpBB3/viewtop...?f=7&t=8864
Edited by Si_GTi
