Camo Roof & Pillars
Basically i really want to cover my tacky grey roof lining and pillars and a camo material, i just have no idea how to go about something like this. I drive a 9n so if anyone knows how easy it comes apart aswel that would be very helpfull,
Jason.
  • Replies 11
  • Views 1.6k
Hi.
First you need to unscrew the visors, remove the interior light, and the grab handles, and all other plastic fittings you may have in the headlining.
Then you need to remove the A, B, C pillars which should all clip out. There may also be an additional panel which goes across near the boot lid.
The headlining should then drop.
Then get your material, and some Hi-Temp 70degree spray contact adhesive. I have found Trim-Fix to be excellent. You'll need about 1500ml, so 3 cans I think, about 6 quid each.
Then spray onto both surfaces and then stick it down from the centre, and work outwards pulling it real tight to avoid creases and get into all the grooves :)
Camo material will be much harder to work with as it's cloth, which won't stretch half as much as vinyl does, so you will get some creases in some areas.
Thanks alot for that, soon as i get some camo ill post pictures, only other thing where can i find trim-fix and will it hold the material to the plastic pillars ok?
Jason
just done this on my 6n,i done the roof lining and pillars in green camo,it looks wicked.just make sure you glue it proberly asnd keep the material tight
put sme pics up :)
get stuck ask oli as his mate did his camo
Trim fix will be fine, it's ridiculously strong. Used it on mine.
i used carpet spray adhesive,ill get some pics up 2mora
Sorry to ressurect this thread after 2 months, but..
After removing the centre pillar cover, is there a simple way of getting the seat belt through it to get it out the car, or is it a case of un-bolting the belt mount?
unbolt the bracket bud.
Olly
The rail type one at the bottom? cant see how to get to the actual reel mechanism.
done, you have to unbolt the bottom runner rail thing on a 9n as the seat belt is thread through the pillar cover before its mounted to the bracket.
Planning a complete interior overhaul, so if anyone has any helpful tips on how to remove the rear door cards (although the're not strictly door cards as its a 3 door...), they would be grately appreciated. ta.
