gt engine in series 1 golf
Hi there,
just about to pull an engine from a mk3 gt with the view of sliding it into my 79 golf.
Now, the first thing that stares me in the face is the obvious engine mount issue.
Has anyone got a link to a similar coversion thread?
I presume a g40 into a mk1 golf would face the same issues so a thread like that would do.
I'm going to keep hunting the various forums as well but if anyone knows of a build thread or has some advice it would be much appreciated.
Just to try an pre-empt any questions, the series1 is a small cc engine bay and i dont want to start cutting and welding engine mounts, plus the gt has recently taken me all the way through europe and back and the whole car cost only 100quid so i'm quite fond of it as strange as that sounds, plus the car has previously been owned by a very close friend of mine and some how found its way back to me so there is quite a bit of sentimental value in it.
I will post a build thread up on here if i'm allowed.
cheers for any help
  • Views 823
theres a sub section in the member gallery for non polo's to post your build thread mate :thumbsup:
i was under the impression that if the golf was a small cc shell then any of the small block lumps should slot in using the mk1 golf engine mounts? i'm probably wrong tho :lol:
the gt drivers side engine mount is set up to bolt on top of the chassis leg, the golf has an engine mount bracket, orientated at 90 degrees to the polo one.
Typically, spent all day today stripping the engine bay and now i'm back home i cant remember what the pass. side gearbox mount looks like!!, i'm hoping that doesn't need modding too..... lol
I feel a full set of frankenstein engine mounts coming on.......
haha, i'm currently cruising the mk1golf oc right now funnily enough!
cheers chap
just thought of another question - will i be able to use the polo gt driveshafts at all?
cheers
