Mk2 letting in water
Drivers footwells are swimming in my mk2 after all the recent rain! I had it all dried out put carpets etc back in a few weeks ago and was great in dry weather.
It's parked up at the moment and I hadn't been near it in 2weeks or so. I had fibreglassed the battery tray up a while back and it doesn't seem to be coming from there, I'd also run a hose from wee black tray under bonnet around battery to drain hole to keep water away from it even. The wee drain on that side isn't bunged as I tested it.
Any ideas as to where else it could be coming from? Doing my head in :-(
  • Replies 13
  • Views 1.6k
Check the membranes behind your door cards, might need better sealing or replaced...
The smallest little tear/gap on these can soon soak a footwell. Also check door seals but is more likely membrane.
These are really drenched, i mean like about 1inch deep of water in front and rear footwell only on drivers side, and seems dry enough around door so don't think coming in there dude, more like up behind pedals. Could the membranes let that much in? Passenger side is fine and that membrane has been off and sealed with tape a few times when i replaced mirror
Lashing again today so can't get much done, aside from sponging and cuppimng all the water out :x
Take your battery out and have a look under there. mk2 are notorius for rust here and holes car appear.
..an elephants eye,was looking at me,from a bubble gum tree.. And all that i knew was,my little MK2 it,was letting in water - letting in water,letting in water..
I have this fibreglassed up and it's not coming from there
I went out today and with a sponde got a large bucket full off water out of footwells!!!
Are there any other holes etc on that side of bulkhead it could be coming through? It seems like leak is worse since I repaired battery tray......as if water going somewhere else!!!! :crybaby:
whip the door cards off and the lower dash tray.....hose pipe each area and watch for drips
if its that wet its coming in at a fair rate and you should see it
its really gota be the battery tray where you missed a bit , id suggest you clean it up from inside and fibre glass that or seam sealer it , door membranes can leak like crazy , or maybe some rot around the screen
feel around up near the pedals ...see how high the leak is
then take the carpets out to dry so it doesnt kill the floorpan
Cheers dude, carpet already up and newspaper underneath top catch anymore.
There's no rust around screen that i can see, so i'll give the hose a go and see if i can see it coming in!
makes you wonder why you bother sometimes :crybaby:
could be rotted under the seal...mine leaked in the drivers corner , with the dash cover off and hose you could watch it drip
Might have to attck the seal with silicone then :sad: Has been bucketing down last few days which means its soaked inside again and it's far too wet to contemplate looking at it
Went out at weekend, and this time took a bucket and a half of water out of footwells! Did as insctructed and fired the hose on, big drip at corner of battery tray that I'd missed! It was dripping behind the carpet and kickplate too so that's why it wasn't wet there!
Fibreglassed it all up with a coulpe of layers from the inside of tray this time and gonna underseal and waxoyl the guts outa it! Fingers crossed that's it sorted!!! :-D
Cheers for all the help lads :-D
take the carpets out and dry it all properly ...or the floors will be rotted out
:x covered bonnet vents with plastic to let the paint on tray dry out.......... came out and the floor is soaking again so still a substantial amount getting in somewhere else!
Was told FROST do a liquid sealant that looks like superglue you put around screen and meant to be good.
http://www.captaintolley.com/
they sell that ...I've used it , it does work well in small leaks and if you can park it somewhere dry until it drys
if its a big rust hole theres no way it will seal it
id keep at it with the hose...find out where the problem is
