G40 Engine conversion
engine, cyclinder head, G40 gearbox, Helix paddle clutch with uprated pressure plate, ecu, wiring loom, inlet manifold, throttle body, boostpipes, intercooler, stage 4 Supercharger (needs putting back to gether with a new oil seal), fuel rail, injectors, standard chip and jabba uprated chip.
pretty much everything you need for a conversion except an exhaust
has done just over 120000 miles, is in very good condition, has had recently: new water pump, new timing belt, Head gasket about 3000 miles ago, New Bosch Lamda probe.
would have to be collection. i live in bolton
SOLD
Edited by VWbreadvan
  • Replies 12
  • Views 1k
bump
emailed you!
I asssume the engine is 'together' with the head gasket, cambelt and water pump fitted, its just thats you list them individually.
Please confirm?
will it fit in a 6n straight in not chopping or out?
No. Needs an engine mount welding in.
Please confirm?
Yes thats right with all fitted to engine
lowered price
Now £850
I can supply charger spares should you need them!
Pete
  • 5 months later...
would this fit strait into a mk2polo saloon?
yes
is this still available?????
Edited by vdub_dan
Sorry this was split and sold few weeks ago
