WOMAN IN NEED OF HELP!
hey, i wondered if anybody knows the cause of my problem...my 1998 1L seems to be giving up on me i turn it on in the mornings and it just cuts out if i put my foot on the accelerator. It does eventually start once i really rev the **** out of it in frustration but when i drive it, it still tries to cut out once i go below 2000 revs in any gear usually, even when warm. Its had a small service recently but the other half had a look at it and said the engine looks fine I'm a typical woman who knows nothing about cars haha. If anybody knows what it could be it would be a great help!!!!
  • Replies 34
  • Views 3.1k
Do the revs just drop on it?
For example, they'll drop then try to recover then drop and then the car cuts?
Does it drive ok apart from this?
Could be a faulty idle control valve?
yeh apart from that it drives fine, it just seems like its choaking :(
First thing i would do rather than just start changing parts blindly is to
get a OBD2 Code reader onto it or even better VAGCOM.This reads
the fault codes on the ECU and should hopefully show where your
problem lies....
problem lies....
this means nothing to me lol a vagcom sounds like some sort of fanny camera... please tell me in idiot form and how i go about getting it done if you ouldnt mind? :)
VAGCOM is VW's own On Board Diagnostics system for reading codes.
If someone owns it and lives near you then it's a 2 minute job to read the codes failing
that most Garage/Workshops have some kind of OBD reader,just a case of phoning and
asking and of course theres always...VW but that'd be a last resort as they ain't cheap.
I have one here but i'm in Scotland and too far away to do owt to help you....
Edited by buster.g40
:shock::lol: :lol: :lol: :lol:
aww thanks for letting me know, I've learnt something, yeh I'm in the south east so scotland is a mish, thanks anyway lol
Not a problem...
You should start a new thread asking for anyone in your area if they
have either VAGCOM or an OBD2 code reader and can help you out.
Not a problem...
i get scared with things like that lol I'm sure one of the other halfs mates has one as they are crazy car nutters, if they didnt, is it expensive to get a garage to check it with the minge camera or will they just mug me off?
could possibly be the temperature sensor? i know thats normally a fix for erratic idling but it costs about 12 quid, and takes 5 mins to fix? cos the part about you saying it tries to cut out sounds similar to what i had for the 1st 5/10 mins of driving regardless of temperature?
the temperature dial doesnt go over the middle when warmed up so temperature seems normal, is this irrelevant?
Coolant temperature sensor giving dodgy readings will adjust the fuelling of the car, causing it to over/underfuel and maybe even cut out.
This does not effect the dashboard display :)
does it use alot of fuel as well, as mine was doing the same but not as bad and mine was the coolant temperature sensor, Automatic choke needed reseting and so did the throttle body had it all done today and all if fine now, cost £50 from a Specialist Vw Garage "Midland VW"
Edited by Po*Low*
Another cause could be your Air intake,
- is your air filter cloged?
- is every thing realted to your air intake connected
- do you own a haynes manual
( doubt it will be air intake related as my polo has no intake sensors, and your polo being older should have any 2,
always worth a check tho)
get your other half to read this as it sounds like you wont know what I'm on about :)
Its most likely that the coolant temp sensor is faulty, or the throttle body needs cleaning and idle settings re-adapted.
Basicly needs to be plugged into a diagnostic computer to check engine fault codes, minimum.
this sound about right!!! i think it is overfuelling, well for a start my clutch bite is so high which is making it over rev, and I've found out today when i drive it, just when it wants to cut out i stop putting pressure on the accellerator. Also yesterday... it made a huge BANG sound which i hope was the dizzy cap coz i found that hanging off, so put that bac on and it was ok, the car stins of petrol as well when it chokes, i think its a bit of a death trap lol ahhhhhh i need a new car
get rid of it darlin' a 1998 1l probably aint worth the hassle.
just replaced the coolant temp sensor on mine, was hard to start cold or warm, now starts first time!
about £8 from gsf car parts and 5 mins to fit - just parked on a hill and used a pair of pliers.
cheaper than a new car!
Mine did similar to this, Leathered the inside of the throttle body with carb/choke cleaner.
Ran it for a few minutes with the airbox off so it would clean out, After that it was fine.
no need to even park on a hill tbh, i can change them without even using any tools!
this sounds pretty easy, i just hope its this :( bloody thing. i dont even know what a coolant temp sensor does haha! could anyone tell me what it does and how to change it?
Hey lads,
as you know my car isnt starting in the mornings, I've narrowed it down on things that not wrong with it....
yesterday i decided to have a proper look at it, the throttle body is in mint condition, i changed the air filter, the spark plugs have been changed, i put some cleaner stuff in the petrol tank, have reset the ECU..everything seems to be fine and working :(
but yet i start it up in the mornings, it just decides to cut out, after about the 4th time of trying it will go 'chug chug chug' and i put my foot down slightly and it will have a hard time trying to go past 2000 revs, then when it does it stinks of petrol, but it drives not too bad, sometimes ill get to a junction and it might want to cut out on me though. has anybody else had this problem? or can suggest anything i haven't checked?
does anyone know what coolant sensor to buy for a 1998 1l polo? is it green by any chance? lol
