Front metal panel under grill & lights warped?
Hi,
I have just noticed that the thin strip that fills the space under the grille and the lights on my Polo Mk3 has warped or been shunted at some point. And I am wondering if I could fix this myself or if I might as well try and get my hands on a new panel.
Aparently the "Dynamic pages in the tags are not allowed" 0.o
  • Views 897
Bump? Please guys. Someone out there must know the correct way to fix this problem =[
They just seem to go like that. mines the same and has warped between the grill and passenger light.
As for a fix i used a flat blade to straighten it but its already bent back.
if you want to replace it then they are cheap to buy from most motor factors, body panel places but it's welded on so you need someone with a welder to do it, plus it'll need painting.
Sweet. =/
I will try and just bend it back then. And see how that goes.
Cheers guys.
