6n2 Front Bumper Removal
Hey guys, I tried taking the front bumper off my 00 6n2 gti and to no luck can anyone tell me how its done...I need to get my headlights out!
Benson
  • Views 2.4k
Popular Days
Remove 4 torx bolts above grill
Remove indicators (using a phillips turn a plastic thing and pull it up) theres 2 bolts behind this to come out
Remove 4 or 5 bolts on each side holding inner arches in place
Using a phillips remove both fog surrounds, behind should be 2 more torx bolts
Should pull off then, be careful with the fog light wiring though as you have to disconnect this first before fully removing bumper
Hope this helps
