Getting lens of front indicator?
right I've sprayed my inner headlights black, looks sweet ;) but anyway i wanted to spray my inner indicators so it looks more smooth
I've taken it out and heated it around the edges but it doesnt seem to want to shift and i think the glue is different so i dont know how people remove it
anyone got any advice ?????/
much appreciated :)
  • Replies 17
  • Views 2.1k
most people spray in where the bulb goes :)
not done it yet myself .. but will be doing it soon
Chris
Yeah i know mate thats what i want to do :)
Jus want to know how to get the bloody lens off!
you cant, spray through bulb hole.
jamie
so how are you ment to sand it down, and get a proper clean finish?
if you just spray through the hole it will just go everywher and have a crap finish?
I'm so confused :(
I dont want to spray the actually lens, want to spray the silver edge inside the actuall indicator lens
I've seen after market ones but they all look so chavvy! unless anyone knows where you can get others from?
Somone help please!!!
£40 for them (link above), rip off. much cheaper on ebay.
do you have a pic of you headlights i would like to see how these turned out. :-D
also don't use a heat gun on your indies, i tried this with my spares and it just makes the plastic bubble even on low heat.
ill try cutting my other spare with a knife possibly saw the front lends off, always glue or silicone them them back together.
these are cheaper
ebay 1
ebay 2 (i have these ones on my 6n)
ebay 3
Yeah let me know if you have any luck :)
will the mk4 6n side indicators fit on a mk5 6n2?
Heres some pics, i have loads of every single stage but only one crappy one of the finished product, but you get a good idea :)
Might do a DIY thread on how to do it soon aswell if people are intrested
Looks good mate, :thumbsup:
Ou can do it but you need to be really careful! You need to heat it slightly and use something sharp to break the seal I used a stanley knife on the 6n ones and then cut and heated around the side! U need to apply Enough pressure to seperate them but not too much so it cracks the lense!
Yeah they can be tricky to do. Gotta heat them up enough so you can cut through the glue with a knife but no so much that you melt the indicator.
I've done my lights but the indicators aint glued together mine are melted together so best option is to get some tiniting spray on the outside.
Thanks for all the replys and comments :)
Ill have a crack at it and keep you updated on this post!
good luck :-)
I tinted my valver lights then bought some smoked indys coz i think all they others look kinda nedish.
Sorry bout it being sideways lol.
Kuszpit :)
My last car was a peugeot 106 and i did this to the headlights to but the indicators were tricky, although in the end i managed to split them apart
this is how i did it.
i got a fine tooth saw from work, the tool moves side to side very fast and has have a semi circle blade
then just simply run the saw round the outside of the lens, then continue this mostion till it cuts right though and you have your indicators lens split apart, then seal with whatever you sealed the main headlights with and the jobs a gooden, it worked for me so it can work for anyone :thumbsup:
manual way would be to use a hacksaw but obvoiusly that would take a fair bit longer.
hope this helps mate
