problem with my TT seats
its taken me and my friend all weekend to fit them.everyone said they were easy to fit. :? however they are now in but the adjuster on the side for the height isnt working ..any help?
  • Views 1k
what car these in? did u have to modify the subframe?
yeah in a 6n2.i used the tt frames and bolted them to metal peices on the floor
needs pictures
They bolted up static? Ie no runners? If so that would explain it! But yea pic would help understand how there fitted!
Mine (which I've just sold) were simple adapted onto a 6N2 subframe, allowed full maneuverability via the TT levers etc. The adjuster you're on about, is that the one that in affect 'sinks' the seat down? You must've fitted them too low by using the current subframe that the floor of the car is kind've in the way now? :p
thanks for the help guys.it was the lever on the side to sink the seats. but yeah iv used the tt subframe on a metal plate and somehow it was catching so we took them out moved them like a cm to the right and there perfect however, the door doesnt shut as easy now, needs a harder push, and when your trying to get out, the door lever sometimes doesnt do anything, and then all of a sudden works,i think its when u push the door away an pull.
