coilovers on 6n2
I've just bought some coilovers for my polo 6n2, do i need anything else?, like top mounts, bushes etc??
or can i just fit the coilovers on straight away using the standard mounts from the polo?
your knowledge would be helpful
thanks Matt B
  • Views 1k
it is reccomended you fit new top mounts and bearing plates, it's not always needed. you can get the remaining life out of your current items.
check the integrity of the rubber on the mounts and that the bearing plate spins freely, depends on mileage too. if they are higher milage it's easier to change them once it's all off and save doing it in 6 months time.
Olly
As Olly's said, best off to change them now whilst everything's off as you never know how much life is left in the originals
where can i get all these parts that i need to replace?
cheers
