6n2 GTI Central locking problems
Hello, I'm new to the forums, just got hold of a GTi polo today :-D
theres a problem with the central locking though, you have to use the key to lock the door (remote locking doesnn't work) sometimes it works to unlock it.....when you press lock or unlock you can hear the car making a noise as if its struggling to lock the door (humming kind of noise)
wondered if its a common problem? an how i would fix?? cheers
  • Views 3.1k
The central locking is an air system where it pumps air through to unlock the doors. It seems as if one of the pipes has come unclipped. I would suggest taking off the door panels and looking to see if one of the pipes has come off underneath. I've had it happen before. Clipped it back on and away we go.
Hope this helps
nice one, is there any guides on how to take the door cards off?
any ideas where the main central locking unit is? the sound it makes sounds like its coming from near the back of the car...
The door cards just pop off with a bit of leverage at the bottom. I dont really know where the main pump is, but I would suggest looking at the clips on the doors first off all and if not, someone else may have helped by then. :)
Nice one :-) hopefully it won't rain tomorrow an i'll be able to have a look, hope its not any thing major!
Got guy at the garage to take off door cards an check for leaks he said both sides seem to be fine, he checked the actual mechanism by puttin a pipe next to it an sucking an blowing the pipe (no homo lol) an it works fine, he said he thinks the motor isn't sending out enough air to lock it...its fine to unlock tho...
The main pump is in the boot behind the carpet on the right hand side if your still looking
cheers for that, found the pump, tested another one- same problem
so it was a deffo leak somewhere, narrowed it down to a leaking rubber seal on the petrol lock - changed that for a tenner at scrap yard - problem sorted - nice one :-)
