Applying lacqeur..
In the middle of carrying out a little respray on one of my panels. I filled, primered and sprayed the colour onto the panel in question. The colour is a metallic/pearlescent red colour and at the moment is looking quite dull/matt compared to the original work.
I need to put the lacquer on next. Do I need to rub down the paint with really fine wet&dry paper before putting lacqeur on? I used halfrauds rattle cans and it says to do so, but I tried it without rubbing down on some scrap metal aswell this one time and it didn't seem too bad?
I also have various sources, some telling me yes and some telling me no.
What do you lot think? Will the fact it is a metallic/pearlescent paint have a difference?
Don't want to cacka this up.. it looks so good and is so close to being done!
  • Views 594
Popular Days
yes metalic base coats will look flat ..totaly normal
the laquer should be put on as soon as the base coat has dulled over ...say 15-30 mins , if youve left it longer theres a chance the laquer wont bond and may peel off later
id suggest a final coat of base coat ...the thinners in this will melt into the other coats, then straight on with the laquer
you dont rub down metalics before laquer
