Removed bumpstrips help
I removed my bumpstrips today but it seems the lacquer has started peeling behind them and as the picture shows it is clearly visible. Has anyone got any advice on what my options are. I might just put them back on.
  • Replies 9
  • Views 1.3k
try t-cut it mate might just work I'm no body expert but it doesnt look like its peeling it just looks like grime nastiness left behind from the edge of bump strip?.. ill get u a pic and show u the state of mine and u will realise u have it easy =] my paint ripped off and i have been waiting to get some money for a spray job and its rusted and rust has kinda dripped down my paintwork :\
I've tried that mate. Didn't make a difference. It's only visible from close up. I was hoping it was just a build up of grime but there is a lip when you run a finger over it. Might have to look into getting it re-lacquered as it does look better without them from a distance. Just thought i'd ask on here to see if anyone has had similar problems. It seems you have had it bad mate, a pic would be good cheers.
haha ill get one tomoz when i get bk from work ill just take the bump strip off and show u the carnage haha need to clean it up am jus gonna spray abit of white over it till i can get it done properly =]
EDIT: spelling
Edited by MattyHolmz89
What you could do is get some 2000 wet and dry paper, wet it obviously and get rid of the edge on the laquer, after that use some G3 compund and buff it back out.
Cheers for that mate i'll have a go at that next week
had the same problem with myne, used high grade wet n dry, then polished it up, werent that noticable afterwards really
have you got any pictures mate? a close up would be good, i'm going to have a go at the weekend.
mine looked bad when first taken off i left them for a week to let the air get to it and then used tcut and a good wash then just rattle can to fix the paint problems
a car wash fixes lots of problems and a good clean fixes even more
yer i did mine as well this week tock them off one side and used sticky stuff remover and it all came off a bute just needed a bit of t-cut but the other side took it off and it ripped all the paint :@ getting the paint work done in a coppel weeks tho sto solt it out :))))
