how do you camber a mk4 polo
how do you camber a mk4 polo????
  • Replies 11
  • Views 5.3k
You can get camber bolts for the front wheels, and shims for the back, i got some brand new ones if u wanna buy some?
Sam
all you need to do is loosen the two 18mm bolts that hold the bottom of the front suspension struts to the top of the swivel hub, and then push the top of the hub in however much you want i believe. then tighten to the setting you want.
take the wheel off to do this obvo..
Sam
i only want to camber the bak a bit, were did u get the shims from, how much you want for them?
Sam
Ah reet, i paid £20 delivered for them and have come to find i dont need them now :lol:
U can have them for £15 delivered, brand new never used :-)
cheers
Sam
Sam
cheers
Sam
ye but are they spacers or do they actually camber the back wheels. can u send me a pic of em to ro_b_b132@hotmail.com
thanks
Sam
cheers
Sam
Yeah, send me pic too..... I'd be interested in cambering a my mk4 if its possible ??
scottmarklester@gmail.com
thanks
Ok, have looked at these, now maybe i'm being daft, but how the hell can a piece of plastic adjust rear camber ??
they go between where the rear shock absorber / rear strut is mounted to the trailing arm thing.
have a look at your rear suspension and it will make sense.
The piece of plastic isnt flat its thinner at 1 side and fatter at the other, therefore, turning the disc would adjust the camber :thumbsup:
Sam
Negative or Positive?
is this just for styling or are you looking for more grip?
C
