Front bumper removal - mk2
This might sound like a dumb question for any Polo pros, only bought the car a couple of weeks ago and its my first Polo.
How do i remove the front bumper? Think it had a little knock before i got it and one side is unclipped, can feel 2 brackets holding the bumper on but cant see up there!
Thanks.
  • Replies 12
  • Views 5.3k
From inside engine bay disconnect battery negative, then disconnect the indicator wiring.
Un do the bumber nuts on each side of the bumber then pull it foward being carefull not to break the indicator wires.
Are they just standard screws holding the bumper on?
Bolts mate, probably 14-16 mil, i cant remember!
13mm nuts ...no need to disconect the battery
reach your hand down either side of the rad to access the bolts ...i find i have to remove the rad brackets for a little more room , but maybe I've got fat arms
reli easy mate, takes 2 mins!
Yep!
Two 13mm nuts in the bay, no need to remove rad brackets etc. if you use a socket extension. But remove the indicators first, two phillips screws each, and then just pop them out, careful not ro damage, as, if like mine, they are prone to rust. Though if its only unclipped, then you may get away with just undoing the nuts to the end of the bolt, and wrestle it back on that way, would save you taking everything off. The indicator wires should have enough slack in them.
Disconnecting the battery should always be done when fiddling with electrics to save shorting the battery
Edited by prankstar2003
Thanks for the info, just gotta wait for it to stop raining now!
step away from the haynes manual lol :lol::lol::lol::?:lol:
theres no electrics in the indicator wiring when a, the engine is turned off b, the indicators are in the off position
theres no way no how he will short the battery , the indicator plugs are also molded into a plug so they wont short if you did try to use them
p.s shorted wires would blow a fuse , not the battery...maybe he should wear goggle and a hi vis jacket too for good measure , and make a tin foil hat incase of radiation waves and aliens
Edited by steveo3002
and a rubber just in case
I just bought my mark 2 coupe, I kinda like the 'went into a tow bar' look at the front, but my bumper does need to come off too..
Where can i find a replacement?! Ebay is DRY of mk2 parts!
Unless they look nice de-bumpered like my Mk1 Caddy does :p
Do they?!
- Steveo
try the classifieds section on here , theres always a few breakers
i think they look a bit wrong with no bumper..but each to their own
