Adding Power steering
Hi guys,
i'm new here..I just bought a Polo (obviously) 6n 1.0 (i choose this engine because it's my first car and the insurance is killing me).
my little baby doesn't have power steering, have anyone here added it to his polo? i was thinking to buy a power steering rack from a polo with power steering and drive it with an electric pump so the fitting will be easier...
what do u think?
  • Replies 14
  • Views 1.9k
i done it this weekend mate,its easy to do.i got the rack and subframe off a 1.4 16v polo and put it on my 1.0l.
just make sure you get the alternator bracket off the 16v engine and the belt to run the power steering pump,it all just bolts straight on
thanks, i will look for the parts soon.
i wanted to go for an electric power steering pump (maybe the saxo one) so i dont loose power, the 1.0 doesn't have a lots of power already!!
did u feel the difference in power?
theres not that much difference in power to be honest mate,the only time you can tell is when pulling off as you have to give just a little bit more revs
i've got a p/s rack for £20 if needed.
Olly
ross how did you wire the pas up??
Drive without? Is it really that bad?
pas is a mechanical system, there's no wiring involved.
All you're doing is running fluid through the rack which makes it easier to turn whilst parking.
you basically need the rack, pipes, pump, the bracket for the pump, belt, the pulleys, resevoir bottle and some fluid.
I can imagine it's a mini arse to fit without a set of ramps and some patience.
It won't be difficult but it will be fiddly.
no wiring up needed thank god,
i just unbolted the whole subframe and rack off the 1.4 16v including the bigger brakes and anti roll bar aswell to put on the 1.0l so it was a nice little upgrade for nothing off my cousin lol
the only problem i had with mine was routing the pipes round the engine bay in the dark as we needed to get it done else i couldnt get home from my cousins garage where we was fitting it,then once it was all routed and fitted we came to tighten the pipes to the rack and put the pas fluid in and we had a leak,on inspection we found that the thread in the rack was f#*ked and the nut wouldnt tighten the pipe to the rack tight enough,so i had to drive round with it like that until i could get a new rack,its now sorted and all working,so heres a tip,dont try and do things in a rush in the dark because things go wrong lol.
Tell me about it man rushing a job always ends up in either u fuckin up or the car fuckin up! So u have the valver subframe on you 1L is it any different? So everything was there to fit it to? I know how to fit the rack by undoing the subframe rear bolts droping it abit then whacking the rack thru the gap,
yeah swapped the subframes over,all the holes and bolts are the same and fits perfect,the handling seems a bit better on corners due to the anti roll bar.
the power steering,bigger brakes and the arb makes it feel a whole lot better,like a different car lol
forgot to mention you have to undo the exhaust downpipe from the manifold and then where it connects to the next bit of pipe just past the cat and undo that clamp and take that section of exhaust out to be able to get proper acsess to everything,
are you planning on putting it on then?
Jus pas yes I have been for a while might be moving and me n the gf car sharing so she needs pas for parking! I'll see about I when I've got some spare cashish! Cheers for the info btw!
thats one of the reasons i put the pas on my car because my gf hated turning the car round with the heavy steering lol
if i go for the electric power steering pump do i need to change the subframe or just the rack?
not sure about that one mate
