new polo 6n temp worries
Hi all I've recently bought my missus a polo 6n 1.4 8v for the decent fuel economey .
Well as you might guess we aint getting good economey, when sitting idle the cars temp will eventually get too 90 ish.
but as soon as i start driving the car temp goes right down within a few mile and sits right at the bottom or lower half of the thick white bottom mark. having read through the forums i though this could be the temp sender which i replaced today , however same thing.
Could this possibly be a problem with the thermostat , and the car idles relativly fine and drive ok other than a slight hesitation now and then
Thanks for the advice guys , ill get some pics of the car up once we start on it coilovers , bbs rims etc going for a nice clean look
  • Replies 15
  • Views 1.9k
I'd say the thermostat is missing altogether.
Only way to find out is take of the thermostat cover on the housing.
Thanks does this sound like a thermostat problem though thats whats puzzling me as if the car sits it gets to temp ok , only drops right off when driven ?
an fuel mpg is pretty low high 30's at best an thats sitting mostly 60 in 5th gear real slow. whilst driving through the revs it does feel a slight surge / hesitation but hardly noticable i though that could be due to the wrong fueling caused by the ecu getting a cool temp reading an causing it too over fuel ?
Edited by lonso69
mine has the same problem and seems 2 be fine
Do you get a really poor mpg also ? as i really dont think that they are supposed to run cold as this generally causes wrong fueling
i guess it would affect performance slighty too for what there is of it on the 1.4 8v
cant think of what else would cause the temps too go right down nearly off the scale when driven
I have this problem to, and always meant to bring it up. My mpg, although i haven't worked it out properly, is not what i think it should be. It seems to be rarther thirsty :(
That said, the car seems to drive well.
Lol seems to be looking like a problem that most wouldnt really notice or care about as the car still seems to drive ok , but loosing 15-20 mpg cause of it. an i only got the car for its mpg so for me this is a big problem. I'm i on the right track with the thermo idea ? could having an f88kd up thermo allow the car to temp when idle an only drop when driving ??
Would Vagcom pick it up?
I scanned my car today and only one fault code came up and that was the idle control valve.
yeah i need to get one for the audi anyway so itl be handy for polo too , did you buy the full programme ?
Ok so i just went out there yes in the dark with a trusty torch. and removed the thermostat. it was closed as it should be i think it had a little play in it by hand i.e i could move it back and forth a lil by pushing the rod dont know if this is normal ? I've stuck it in hot water too see if it opens ok
Ok so the thermo was open when i took it out the car not closed , and when i put it in boiling water it didnt close so i guess thats f88kd
i will buy one tomoro and let you guys know does any one have a pic of a thermo open they could post ?
Edited by lonso69
hitting around 40mpg for a 1.4 8v sounds good, you wont get much more than this imo. i get just about 41mpg, but thats with cold starts short journeys etc.
Hi most of my journeys are 30 - 60 miles at a time doing mostly 60 ish , so i would be expecting more than 40pmg a few people who i know have these do get low 40's on short journeys or town trips thats normal but motorway journeys etc should be alot more.
an i cant see the car running on cold all the time helping the general seems to be around 100miles to a 10er of fuel mixed driving. there seems too be alot of people getting less mpg in there car than they should be
Classic thermostat stuck open symptoms, sounds like you've nailed it and a new one should solve the problem.
You're lucky it wasn't down to an overheating problem and the last owner whipping the thermostat out to hide it, seen this on many occasions.
Nick
Nick
Hi guys so i bought new thermostat this morning , i also checked the housing which was perfect so that ruled that out.
fitted the thermostat and problem solved , runs to temp quickly and stays there .
Yep classic thermostat stuck indeed. so new themostat , coolant temp sender , and tin of throttle cleaner. total cost £24
car should be back up on economey and some piece of mind
So anyone else with the problem an thinks there car still runs ok, id suggest change the thermostat cheap fix so its silly not too
A little update . car has been running at temp no probs, for about 10 miles then the water low light starts flashing and so it goes on all day an about 5-6 litres of water
I check too see there is now a big hole in the radiator at the bottom corner. all i can think is its been run cold for a long time
now its back to temp and the extra pressure cause by the hotter water broke an already weak (rusted) part of the rad.
Oh man 3 days or so ownership an all this lol . fuel seems better but il give a definate on that afer I've used a tenner
Replaced mine today too :)
Nice to finally have hot air again when driving :)
Good lad easy an cheap hope yopu dont end up with futher problems like mine .
Let me know how much better you are mpg gets cheers
