6n open air leaking !
hi guys i just brought a 6n open air , and guess what the roof is leaking i knw this is a common problem so I'm hoping that someone can help me out its leaking into the runners and then through the motor mostly it has a few tears in the top layer but i have ducked taped them and it seemend to work for a while :-( but not anymore can anyone help me please
cheers
  • Views 999
Black silicone...
Black silicone...
thats what i thought but someone said that it would make it worse if i opened it?
Just make sure you use the right stuff.. I make uPVC windows so got some of the black stuff from work, stays flexible and is proper sticky out of the tube so it sticks well..
Mine had the usual couple of tears on the edges and it sorted them fine..
Stick some in the hole but not so much that it will block up the inside.. then stick a patch of duct tape over the hole as a bridge then seal that over with silicone..
ok mate thanks will get some tomoz
