spraying
If i were to rattle can a pair of bumpers, how bad would it look? I've never seen or done it before.
  • Replies 10
  • Views 1.2k
what bumpers we talking about? I rattle canned my black plastic MK3 bumpers and they look wicked.
6n 16v bumpers!
depends what colour?
no need to shout it lol , you should have stated it in the first post or title!
easy job and looks good after i did mine from blue to silver just over one can of primer and then about 1 and a half of paint with a can of lacquer to finish it off
I'm really consederin rattle can'n mine yours dont look to bad pal, you do it outside or garage?
do it inside if you can,nothing worse than getting it all done then having to flat flys and dust out of dried paint lol
It all depends on what standard of finish you want really. The key is good prep, painting is a small amount of time to do. Best to practice first so you can get used to optimum distance, speed etc. Also, get a spray can with a nozzle that gives a straight spray profile, not a circular one. These are best obtained from a specialist body shop provider. Dont go with halfords et al, for nothing else that the colours are only the most popular shades of the colour you want. a bosy shop supplier should be able to give you the colour and right shade
Heres my front bumper i sprayed after i smoothed off the grilles on my bumper. I used rattle cans for spraying it.
prankstar2003 is right about getting ones from an actual paint supplier not halfrauds.
any questions just ask
Kuszpit :)
paint is paint, getting it on is the main goal (put simply) a gun means it go's on heavy and flat meaning its quick and not labour intensive.. cans are fine but it takes alot longer/more coats/more wet sanding (risky wiht cans) but dont lewt it put yhou off, aslong as you can get the paint flat it will come up shiny once you compound polish it. fact is you can brush paint an entire car and have it looking like a pro spray job, it would take a year of sanding with some REAL skill tho..
put bluntly, this was painted in a shed, with cans, no clear and its metalic...then sanded correctly, then i used nothing but T CUT AND A DUSTER to polish!! speaks for itself i think
for comparesen to the worst of the spraying (reacting all over the place, hey it was raining outside and i was in a less than windproof shed
you have done a good job tho m8 it is unnoticable, just wet sand it and it will SHIIIIIIIIIIINE (not just this, the whole body, factory paint is just POOR)
Edited by MiNoR cOnFuSiOn
