Garage suggests i raise my car (6n)
Today i took my car (6n) down to a garage to get the exhaust sorted out, and they advised me to raise it an INCH :o
The drive shaft rubs, petrol tank has took a bit of battering and the exhaust is getting hit most the way down the car.
what do you reckon? i dont realy fancy putting a leak in my fuel tank for obvious reasons lol, do they take alot of battering to get through?
cheers!
Dale.
  • Replies 26
  • Views 3.8k
Its your choice isn't it. The garage have advised you to raise it to prevent further damage. You want it as low as it is so it looks the way it does. So you choose form or function.
Lower it more :D
Depends, it won't look cool with a humungous fuel leak/fire. The driveshaft isn't good as it is, a lot of people have the inner wing cut and sleeved to stop this.
ye i was thinking the same thing tbh, I'm more worried about the petrol tank than the driveshaft obviously.. as I'm only on standard 13's aswel, might have to invest in some 14's or 15's so it still looks decent but will be sitting a bit higher hopefully.
Dont spose theres anything you can do about the petrol tank realy is there? how do other 6n's deal with being low and munching there petrol tank lol?
do you know how low you car roughly is atm?
My mechanic is the same.
I believe his words were:
"For F**K sake zach, next time i see you the car will be in flames. Look at the state of your effin fuel tank and how close it is to the exhaust!!"
its on TA technix coilovers wound all the way down front and back? so about 100mm maybe?
Lol i did look at your car earlier and thought "he must have the same problem as me" have you done anything about it? fuel tank or driveshaft?
Get a pic up, lets see how low this thing is!
The local garage I'm friendly with is almost the same, never said raise it up but are impressed I still drive it so low to the ground.
They even invested in special ramps so I can get the car onto the four post lift easier :)
But if your giving your fuel tank a good enough knock to puncture it you will have killed your subframe and exhaust and sump first and be going quick enough or silly enough to keep driving with the underbelly of your car making horrible scrapping noises off something....or your just extremely arse down, in which case I would suggest you raise just the back up an inch.
if i know its going to scrape anywhere i will go over the bump realy slowly, i never smash into anything, its just scraping. it does look a bit arse down tbh
jus took some pics, car needs a clean Lol :D
leave it :D
Ah thats not low :lol:
I'd maybe raise the back a touch but it seems a nice height.
ye i know i didnt think it looked that low from the pics tbh lol, i think its the dodgey speedbumps at college mashing my petrol tank up :/ il try bringing the back up a touch see how much that helps, i want to get some new wheels on it soon anyway!
lower it
mate i think you find alot of people have the same problems. my driveshaft knocks constantly but you learn to get on with it!lol
i took my car up 30mm for my MOT and they said it was still too low. but passed it anyway...
raise the back 10mm. that will do it!lol
you know your low when you have to park on a plank of wood just to get a jack under :-)
failing that,sparks are a good indicator....
Done nothing mate :)
I like it that low, and it doesnt cause too much of an issue as long as you just go slow over big things....... :lol:
a hidden backbox might be worth considering too.
if its not rubbing its not dubbing !!!! leave it man!
Arrgghhhh that phrase winds me up :x:lol:
It was cool once, just like vanilla ice
Agreed, also hate the rest of the generic sayings
Like
'Lower than your grans tits' Etc
and for some reason i dispise the word 'VeeDub' and dont like it when i get refered too as a 'Dubber' :lol:
*Edit*
On topic, Dont raise it many (inc myself) have ran lower, with no worrys, just learn how to drive a lowered car
E.g dont rag it anywhere, drive VERY slow over speed bumps and pay attention to camber roads and pot holes!
Edited by Leigh_p
Like
*Edit*
i basicaly stop over speedbumps lol, avoid every pot hole possible aswel!
I'm not all that bothered about the backbox hitting things tbh, the fuel tank worries me the most!
Fair play, ye i love it low to, its just a bit worrying thinking about the concept of going through your fuel tank and possibly setting your car on fire :S
Lol fair enough, il give it a go see how it turns out :D
I'm wound all the way down too and my mechanic is the same, said its too dangerous to be driving that low,
i do have some gorges out the petrol tank though, easily fixed,
jack it up, un-strap the tank and put a one of them square metal road signs over it, cut it to size if needed and strap it back up, wont take in in-destructible but definitely stops it from being pierced as easy
Edited by V-Dubble-U
Don't worry about the fuel tank mate! That was me that done that when I had a car full of passengers and went over the speedbump that's always been there at Weston Favell.
I got beached on the speedbump and had to get my passengers out to raise the car slightly to get over it. Bit of man and engine power and the car was off, only with a few scrapes to the tank.
I did originally spray the tank with some black in case it got seen going through MOT so if there's paint knocked off it, it maybe the case your hitting that big hefty speed bump near the mobile rooms at college! You may wanna avoid that one ;)
Edited by jooshy63
