Polo 6n2 gti
Hello all, the name's Tom, just joined the forum today so i thought i better post something up :-)
I've been driving since i was 17 (19 now) and have had a 97 mk4 fiesta since i passed. basically I'm in need of a car change.
i drive 250 miles a week to work and back so i need something reliable and safer than my ford, oh and quicker for abit of fun on the country roads i mostly drive on :p.
I'm really interested in a VW and i have been doing a little research into Polo 6n2 gti's as a second car, this seems like the most likely car to get as it fits the bill for me, and the insurance isnt too steep.
a lupo gti was also on my mind but they are out of my price range. I'm willing to spend up to 4k, but would be happier with something around 3.
are there any common problems that i need to look out for when looking to buy one?
i also intend on tastefully modifying it, any recommendations would be greatly appreciated.
Thanks,
Tom.
  • Replies 9
  • Views 1.4k
Can you really get a Mk5 GTi for less than a Lupo GTi?
Surely it's teh other way round, or they cost near enough the same?
Tbh I'm only going by what I've seen on autotrader.
The six speed Lupo's seem to be around 5k and and the five speeds about 4k, theres also much less available atm. i also ruled out the lupo because of its size. i play in a band and i need something big enough to fit my guitar amp cabinet into.
Lupo's are too small for me! They even actually cost more! I could do with a 6th gear though
Hi Tom,
I asked a very similar question on the forum before I purchased my 6N2 GTi last month, see below for a buyers guide:
Common Problems
Gearboxes & Clutches
Tend to be the weakest point of the GTi. These are prone for going wrong, especially if driven very harshly. Expect the higher the number of owners to mean the car has had problems, often leading to it being passed down.
Typical mileage for gearbox going wrong is about 60,000 miles. Some last less, some last longer, it all depends upon how the car’s been treated.
The best way to look out for a dodgy gearbox, is to feel the transmission, to see if there are any difficulties selecting gears. If when driving, there’s a strong whining noise, it needs to be looked at. The most common problem is the 5th gear bearing.
Again, a car running significantly more power than standard is more likely to give the gearbox more trouble. If you see a car with no performance modifications or one with, go for the one without, as it would mean the gearbox would have been placed under less strain.
Expect a gearbox rebuild to cost around 600 pounds. If it does need to be carried out, replacing the clutch is strongly recommended.
Clutches tend to have similar lifetime, i.e. 60,000 miles.
Replacement options are either Valeo, LUK or Sachs Clutch Kits. Valeo are the OEM option, however they also offer an aftermarket version. A clutch kit generally costs 100 pounds, if you are given the option of “refurbing” the clutch or a new one, go for the new one.
Engine
Tends to be the most crucial element of the car. GTi, by the owners manual, should be serviced every 6 months, 5000 miles (for an oil change) or 12 months, 10000 miles (for an inspection service).
Typical cost of small service is 100-140 pounds. The inspection costs roughly 200 pounds.
The cambelt is a known weak point in the engine, and needs to be replaced every 40,000 miles or 4 years. If it’s not attended, it could result in bent valves, requiring an engine rebuild.
Another small weakness in the AVY engine, is at about 70-80,000 miles, the oil stem seal valves have been known to go. This is a rare occurrence, and could cost around 300 pounds. Check for white smoke upon start up from cold.
Pedal Box
Due to poor welding at production, VW have made a recall of all GTi pedal boxes. You can ring up your local dealership and they would be able to find out for you if yours has been dealt with.
Other Faults
Just as any MK5, the GTi tends to suffer similar electric faults. The window motors are prone to breaking, so check all windows work, before purchase. A new motor is about 100 pounds.
The central locking pump can also be likely to fail, if it has been exposed to unnecessary moisture. It’s located behind the First Aid kit in the boot, check for any signs of water. A new pump is 160 pounds, however can be picked up from scrapyard for about half that.
Air-Conditioning needs to be regassed on average every 2 years. Make sure it’s working, as a regas generally costs around 100 pounds with purging of the system.
A new compressor from VW is 300 pounds, so is a hefty expense, it would also need to be installed, expect labour charge of 100 pounds. Therefore it’s important to check that air-conditioning works.
Faulty ABS sensors/Dirty ABS sensors can lead to the ABS light up on the dashboard. This could either be the sensor, or the actual “system”. A new sensor is about 20 pounds + fitment.
Ignition management light – could be up on the dashboard, as the GTi is meant to be run on Supreme Unleaded. Putting 95 RON would lead to lambda sensor giving erroneous readings.
Corroding Alloy Wheels – Due to water getting under the lacquer. GTi has Split Alloy Wheels, so refurb is more expensive than that of 1 piece alloys. Expect to pay 60 pounds a wheel, or you can do it yourself. There’s a guide in the DIY Section.
Leaks in the boot/washers – hoses are common for breaking, cheap to repair just need to identify it.
Grab Handles Peeling – These can be bought new from VW, 30 pounds for inside and outside grab handles for both sides. If buying from a dealer, make sure they replace them. The same could be applied to the aerial base and the chrome door catch.
Happy buying!
Thanks very much mate, I really appreciate it, that's a really helpful guide.
I'll probably be starting to look for one nearer the end of he month when I've got abit more cash.
Yeah I've heard a little bit about the whining gearboxes but most of the other stuff is new to me, hasn't put me off though.
How's your Gti going? Did you have to look at many to find the right one?
Thanks,
Tom.
Thanks,
Tom.
My GTi's sweet mate, I'd wanted one for ages! (pics in my gallery if you fancy a look).
From what I can gather it's pretty obvious if theres a gearbox-related problem, there would be tell-tale noises/crunches.
Most of the other problems are cosmetic, and more importantly not exclusive to the Polo, therefore relatively easy to spot.
Best advice is to drive a few, you'll soon separate the wheat from the chaff!!!
I got a Black, 5-Door, 2001 (Y), with a reconditioned 'box & new clutch with 74k in great condition for £2750 which i thought was pretty reasonable, although I'm sure there are others on here with tales of bigger bargains!!!
I've gotta be honest I didn't physically go and see many at all because of the relative rarity of the car, and therefore the travel involved.....and to a certain extent let my heart rule my head, but that's just the kind of guy I am (and the type of guy most GTi drivers are too!)
Your gti looks awesome man, black is definately the best colour I think. £2750 is really good aswell, bargain!
I think it's gonna be the same for me, I work most days so going to look at a few in the future might be tough. I'll just find one I'm confident in and hope for the best.
I'll keep you posted.
Lupo GTIs hold there value much better. MK5 GTI is more or less a MK5 with GTI bits added on it. A Lupo GTI is bispoke. Has a wider track, bigger brakes, alloy doors, alloy wings, alloy bonnet, different arches, xenon headlights, can get a 6 speed box for them, different trim etc etc.
Defo get one mate,you wont be disapointed,i love mine,superb little motors ;)
