Massive Clearout, 256mm brakes
Due to Travelling again my polo plans are now non existent.
Vauxhall 256mm calipers and shoulder bolts. Direct fit to polo 1-3. All you need is 256mm discs of a golf mk2 16v (40 pound from GSF) and you have much better brakes. Have cleaned them up and given them a quick coat of blue, will also throw in the paint to do them properly.
Looking for 50
http://i767.photobucket.com/albums/xx316/H...45/DSCF6317.jpg
All items located in Hudds and will post at cost but dont expect it to be too cheap as most of it is heavy!!!
Also if your desperate for pics before i sort them email me on jj19082008@hotmail.com and ill send them,
Matt
Edited by hirdy12345
  • Replies 10
  • Views 516
sign up to www.photobucket.com and copy the links across mate.
On it now
ill definetly have brace bar and lowering kit! pm me paypal details and price posted mate!!!
Edited by Rodder759
I'll take the anti-roll bar mate, and the golf drums if they are full shoes, drums and fitting kit.
I can arrange a courier too if your pack up the ARB?
drop me a pm with details and we'll sort it out
Ta!
Saf
Ta!
Saf
Hi mate have you still got the 256mm calipers?
Ta!
Saf
Yes mate still available
Ta!
Saf
Do they use the original g40 carriers or do they come with carriers. Would I need a 22mn master cylinder to run these
or are the ok on standard setup?
You use the vauxhall carriers (with the m12/10 shoulder bolts which are included) which have the same bolt spacing. Just add the 16v 256mm discs and your away. As for the 22mm cylinder its up to you really. Id have a look as there is a bit of debate on whether to use one. I was going to use one if that helps lol
So does this setup include the carriers or not pm me if you could thanks :)
hello fella, what vaxhall do these come off of?
