22mm brake master cylinder off 16v golf
As title, used but no problems at all. Just had a new pair of rubber seals for the fluid reservoir. Straight fit onto mk3 polo, reduces play and decreases braking force required.
£20 posted
cheers
  • Views 200
Does this include the servo? If it does i'll take it, cheers
servo was broken mate think the 1 way valve thing in it was shot, so no I'm afraid!
ok cheers mate, so you just used it with the standard servo?? Make a big difference?? Cheers
The bigger servo is a nightmare to fit i found anyway, makes a great difference to the feel, braking is much more responsive, especially if youve got g40 brakes on too, this helps a lot!
up
20 posted i'll take it dude?
