Seat Belts
Hi guys,
Can someone tell me if there is a difference between the seat belts of a 5 door and a 3 door 6n2? Only reason I ask is because i'm putting a set of GTi ones in mine but I need to know if I should only be looking for 5 door models as mine is.
Cheers :-)
  • Views 896
i doubt there would be any difference to be honest mate as you only use how ever much you pull out,and aslong as the locking mechanism isnt broke inside then it should lock when they are pulled to fast like in a crash so to speak.
try pulling them out all the way to see if theres any difference in the lengths,I'm pretty sure they are the same though
Cheers mate :)
I'm not sure as someone mentioned that the mounting points are different and they can't be changed over. Only really wanted to do this as there are a few GTi's being broken atm and its hard to find a 5 door :)
The mounting points are different and they can't be changed over as iv got a 5door and my seat belt broke so needed a new 1 and in the scrapy they only had 3doors so i thought it would be the same but its not as i trye fiting it sorry mate.
Thanks for clearing that up :)
Means my search for the GTi belts are going to be even harder :(
