wheres the 1.6's?
hey everyone, new member looking to buy a polo. the question i have is how comes theres verry few posts about the mk4 1.6 8v? is it mearly down to insurance or somthing? this really isnt an issue to me tbh id just like the strongest biggest engine to start with in an early mk4 3 door and cant see the 1.4 16v being the best option for future work.. i have considderd a golf 1.8 after a friend put a goldf engine in his altho the driveshaft and mount issue is well, an issue as i have nowhere indoors i can remove engines/mock up mounts, if anyone had drawings for the mounts id be appreciative and it would make my mind up fairly easily, however i have been toying wiht the simplicity of fitting a charger to a 1.6..
any feedback/info is welcomed greatly, as i say verry new to polo's altho I'm from an engineering/engine building background.
great forum btw
  • Replies 30
  • Views 3.1k
What would be wrong with a 1.4 16v btw? They are the most powerful - dunno about strength etc though sorry :lol:
reason you dont hear much about the 1.6 8v is that its not very popular, not really that strong and take some effort to tune. the std fuel injection system on it is really restrictive, its not really suited to turbo or supercharging, although it is possible with custon pistons/rods
the engine will put out reasonable power with a decent fuel delivery system such as itb's/ bike carbs or gt injection
so the 1.4 16v really is the best way to go? bearing in mind new pistons/rods/crank grind/balance aswell as alot of head work/supercharging/turbo (prefer the super) is in the pipeline so that aside the 1.4 still better option? can you not fit a 16v head from another engine to the 1.6? (really dont know much about vw's.. been into fords/mini's/5 turbo's but always wanted a polo)
basicly, insurance is not a considderation, nor is work, I'm after the best RELIABLE power for the money, this needs to plough motorway's fairly regularly hence my thinking for the 1.6
1.8 20v turbo ftw tbh
Use the 16v head with the 1.6 gti bottom end from the mk5 polo gti. You'll have problems with the head bolts being to short I think it is, but it's becoming quite a popular conversion the power gains combined with other mods ie: cams headwork, exhaust system etc are quite reasonable 130-40 bhp.
but this again calls for custom driveshafts aswell as alot of exhaust/intake pipe work... may aswell go buy a bigger car for the work... dont mind any ammount of work but if it involves squeezing silly parts into silly small holes and anything other than readily avalable parts (bar one or two here and there) I'm not for it tbh.. hence I'm asking what engine's best to start with in the car. from the reply's so far its stick wiht a 1.4 16v and aim to turbo/supercharge this at some stage...
there have been 1400 16v engine turbocharged before , so its do-able as is the 1600, but surely the 1.8t is the most logical engine to use, as
a. its been put in a few 6ns now, so theres pleanty of info out there
b. its designed to run boost
c. tuning potential is far greater. compare how many 1400/1600 exceed 200 bhp compared with 1.8t engines
did skoda or someone not make a 1.6 16v engine which will fit a 6n?
looks like itl be a 1.4 16v then for now with a view to doing somthing.. NOT changing the block from the one i buy wiht the car or else whats the point? i could just go and BUY a golf 1.8 turbo (or bigger for that matter) fact is i want a semi tunned motor and want to know the best one to start wiht... altho people have this amazing fascination that changing the block is the logical thing to do when tunning a car :S:S:S:S:S
6N2 GTi (1.6 16v) engine fits into the 6N chassis.
the point is that there little point in throwing money at an engine that isnt very tuneable. if i were you i'd forget the polo and buy an ibiza instead, that way you could go and buy a 1.8t cupra.
anyhow you opening post talks of putting a golf 1.8 in, or was i dreaming?!
none of the small block engines (bar g40 engine for obvious reasons) are that suited to charging, esp. the 16v and 1.6 8v and for the hassle it involves it just doesnt give good enough gains. and even if you do get it to work it'll blow the gearbox apart, as they are made of chocolate on mk4 polos.
Just buy something with a 1.8T as standard....
The 1.6 6n would be a far more desirable if it wasn't for the 16v.
I used to have a 1.6, but if I was ever to buy a 6n again it would be a 16v, because of the tax band.
see this is what I'm trying to get at.. i want a mk4 3 door polo... i wish to know what engine is the best to tune (in any circumstance) as i wish to keep the ORIGINAL block and not have to mess about wiht allsorts of extra stuff.. i dont even mind doing a head conversion aslong as its to the origina engine and i cant buy one in the first place (like a 1.6 16v conversion of some sort)
again, i could hapily go and buy a 1.8/2l turbo/vr6/r32 golf but id like a mk4 polo.. i just like the look....
christ i might just get a 1.4 16v and leave it the hell alone.. i sure as HELL arnt going to buy a seat :S:S thought this was a polo forum :S
Well the older Ibiza was based on the same platform and both were built in Spain, but we wont go into that as this is a POLO forum as you say....
None of the 6n engines are majorly tuneable..
1.6 8v 75bhp or 1.4 16v 100bhp..
Aftermarket cams, bike carbs and head work might get you 25-30% more power on those engines..
You're saying you dont want to change the block..
But you could either drop the 1.6 16v engine in from a 6n2 GTi which will also require changing the ECU and clocks i think, that's 125bhp..
Or, you could use the 1.6 block and the 1.4 head, which wouldnt be much more effort if you've already got an engine in bits out of the car...
seing as how the gearbox's on these are chocolate what engine shares the mounts and has a nice sisplacment/tunning potential? just the newer shape polo engines? obviously the ecu/entire wiring loom/clocks going in are no biggie.. i just cant warrent spending hour upon hour on the mill/lathe nocking up bits to put an enigne in when i could just buy a different engine/car to start with... :S
looking like its gonna be a 1.4 16v then :S
thing that gets me is, a pair of cam's for a 16v cost more than a supercharger and thats literally a belt pulley and a bolt on plate i need to make aswell as a couple of blanking plates and some pipework, still minimal instalation comparitivly, if the boost is kept low the stock pistons should cope (assuming it doesent run silly high compression to begin wiht) and a simple remap.. polo's are looking like a slow option bang for buck unfortunatly... might have to keep the 5 if I'm pissing about with 1.4's :S
Tuning the 1.6 is all very well but you're better tuning the 1.4 16v - and one of the first mods is a crank/piston/rods change to increase the 1.4 to 1.6 litres,retaining the 1.4 block. This actually makes far more practical sense than adding a 16v top to a 1.6 8v because you cant put a 16v head onto the 1.6 8v block anyway. A remap makes it run well (reports of over 140bhp),or ITB's and cams (reports of over 160bhp) for all the top-end you need without a turbo.
Then whilst you could turbo the base 1.6 16v,you'd be hunting more power than the engine is ideal for. Wrong cams as standard,relatively weak rods.. If you want big power you'll want a 1.8T,so you might aswell just buy a 1.0/1.4 8v and put the big engine there in the first place.
aspirated is fine aslong as its over the 130 mark as like i say its gonna be used for steady motorway work so needs to be low in the revs at 70, again my thinking behind a larger engine to startt with.
you say reboring to 1.6 is common, altho how much space is there between cylinders? anything to worry about? somone else mentioned the gearbox's are made of german cheese, can anyone confirm/give me options on this? it really is looking like a 1.8... altho it may just be easier to leave it aspirated (any specific engine easier to dump in or are they all the same?) only thing that honestly puts me off is a, having to prittymuch buy a golf for the engine/ancilaries and b. it will no longer retain the original engine numbers.. yes its not a legal requirement to HAVE numbers but it would be nice if it all mathed up when I'm finnished... not looking like that tho.
so ye, anyone know a straight aspirated 1.8 thatl go in easier than the turbo or are they all the same block/mount configuration?
again, why pay some small engineering firm when i can just do it myself wiht a mini supercharger and a 1.6? do the 1.4 and 1.6 share the same gearbox?
nope, different ratios. i had a 1.4 16v gearbox on my 1.6 8v and it was NOT a comfortable motorway cruiser, 4000-4500 rpm at 65mph is noisy...but the shorter ratio did mean it was quite quick through the gears, suprised quite a few cars with it, until we reached 50 :lol:
You mean naturally aspirated..
always one isnt there... wow you picked up on a mistake.. harsh burn :s
back to real life.. anyone other than mikeymk know what there talking about as lots of people have been telling me 1.6 wiht the eaton charger where as nobody on here seems to agree....other than the professionals out there :S makes no sence.
