rolling arches
i need to roll my rear arches, does anyone know how much it will be for both rear arches, and will the paint crack or sumthin? cheers :-)
  • Replies 13
  • Views 2.9k
think it costs about £23 an arch, so your looking at around £50.
Depends how much you want to roll them tbh. It wont crack on a little rolling but the more and more you roll the higher the chance of paint cracking
:thumbsup:
if you have a crease or a small ding in your arch then the paint will probably crack tbf.
mine took some right pasty and the paint only cracked where it was damaged already - seems it's all about the heat gun
cheers for the replys :)
Heatgun and rubber mallet, around 20mins each side, done
Before:
After:
Before:
After:
that looks spot on mate, did the paint not crack at all no? did you just keep heating it up and hammering at it slowly yeah? :-)
that's an improvement but I'd recommend getting it done properly, that lip will roll tight up to the panel.
Yeah the heat is the key, just to soften the paint slightly. I wouldn't say I did it slowly either lol I got bored of slow hammering so I just used big hard hammering but I wouldn't suggest it haha. If I had gone more it probably wouldve cracked but this is all I needed doing, but if you want to go further I suggest to get it done with a roller.
:thumbsup:
just wondering where you got them done for 23 quid as i've got some corvette rims to fit on my 9n and there's no chance they're fittin without rolling..
cheers
chris
i CAN DO YOUR ARCHES FOR YOU AT £25 PER ARCH! THATS HEATED AND ROLLED SO IT SHOULDNT CRACK YOUR PAINT! ONLY DO THEM ON A WEEKEND THOUGH
LET ME KNOW 07791205278
mine were £20 an arch @ bandedsteels.com
sorry wayne, wasn't trying to undercut you there, we posted at the same time :lol:
NO PROBS DANNY6N
I FORGOT TO ADD THAT I'm MOBILE
ALSO I DID ARCH WORK FOR 8 YEARS AT WHEELMANIA SO IF YOU ASK ABOUT I'm SURE YOU WILL FIND SOME INFO ABOUT ME!
OR CHECK OUT THIS LINK ROLLY
