6n2 front fog light fitting
Hello,
I am looking to fit a pair of fogs to my 6n2, I have had a look on www.veedubmachine.co.uk and have found the fog lighs, the front grills and the interior replacement switch.
Are they the only parts I need?
Has any one seen a how to guide?
Sorry for being a noob.
Scotty_24
  • Views 1.4k
Thats all that should be needed as all the wiring is already there.
Just remove the original grills and the wiring will be tucked away behind them and attach the lights and the grills.
Remove the swich by pushing the swich and turning it to sidelights and then pull it out.
Thanks very much for your help mate, Il get them ordered asap. It sounds like a ten minute job, is all the wiring plug and play on the switch as well?
Sorry to annoy you with questions!
I did them a few weeks ago, 10 minutes tops. Remember you need to get the bulbs themselves as well as they are not included when you order the lights.
With the swich just unplug the loom from the previous switch, connect it to the new switch and lock the new switch into the dash.
