Toyota Yaris door replacement
Ok then, today a mate of mines 2dr Toyota yaris (one of the old skool ones, T reg i think) was crashed into by an uninsured van
by the sounds of things the door is completely knakered, and he says the framework of the car is not bent.
His insurance execess is £500 quid, so they will not pay for the job to be done, and hes just paid for a new clutch for it so he cant afford to get a garage to do it what will cost like 400 quid
Soooo.... Being the only one out of his mates who actually knows anything about reaparing cars (and thats not much, just little jobs on the polo) I've ofered to try and help him
Does anyone know if replacing the door is a simple enough task on the yaris?
Any information would be VERY appretiated!
  • Views 2k
what ever you do i would recommend when changing a door on any car, take the wing off aswell and then you can access all the hinge bolts for realining etc, it took me ages to put a door on my polo with the wing on and an absolute dog to line up, but I've done it with the wing off and another foor it took half an hour tops!!
Nice one mate, cheers :-D
i changed the rear door my my old yaris, pretty simple, just remove door cards and unbolt
fitting window from old door might be a mission tho?? but it can be done...
Ahh cheers ill make a point to buy one with glass inside it already. What about locks? are they easy to change over?
from what i remember, it was pretty simple, just fitting window was a problem, because it was a manual wind one, n lining it up right was tricky, but front should be electric so might be alright? scrappies normally charge extra for glass....
Use a jack to help line the door up. Shouldn't be too hard took me about an hour to replace both doors on a 6n on my own.
