Boot change..
I'm swapping over to a new boot for various reasons. Its been sprayed an all just waiting to go on.
Is it an easy job.. i haven't even had time to properly look yet but what do i need to remember when changing it?
Its a heated windsreen if that makes any difference..
right ok here goes,
if you take the boot liner out of the lid, you can unplug the loom and pull it out of the top, bit fiddly but better than taking all the rear passenger side trim out
open the boot lid up, you need to remove the platic trim that goes along the top edge of the headlining
theres 2x 10mm bolts, just undo them and it comes off, be careful tho, you might wanna get another pair of hand to hold it steady,
take it off and reverse the process for the new door, another person or two people to hold it steady if you worried about your new paint, easy half hour job, I've done it a fair few times
definately get a mate too hold it for you, makes the job so much easier, if youve removed the rear wiper the job is even easier as you dont need to rethread the loom through
unless you want heated rear window!
heated rear windows on a seperate loom too the rear wiper! or at least was on mine
Orite well thereay be 2 types as the one I've done had all the electrics and washer jet pipe down passenger side an only the central locking vacuum tube down drivers side, ull probably have to make an educated guess!
cheers lads, brilliant info.. ill give it ago this weekend.
