Polo Mk4 buying guide
Hey all,
Brand new on here - I'm looking at a few polos this week - mk4/5 and wondered if there's anything specific I should be looking for. I have a Corrado so I'm well aware that there are some foibles that only current owners know about so hit me with them!
Cheers,
Cole
  • Views 2.6k
mate i think your going to be quite clued up on them if you already have a vw. why are you wanting a smaller car though??
rust on door, arches, around windscreen & sunroof.
check for leaks in the footwells & boot
gearbox & cambelt
that about covers it apart from what youll already know about
gearbox & cambelt
another common probelm with mk4's is the clutch pedal box weld breaking, mine went and it cost £220 to get repauired as you have to remove the steering column :/
Thanks guys,
seanvw, Corrado is mid-rebuild and my MK3's just given up the ghost, needs loads of welding and oil in #2 so I'm looking for a nice little economical runabout.
Mattnaz, cheers will put it on the list - any other obvious ones?
gearbox, gearbox , gearbox!!!!!! the pinion bearing is shite in them
gearbox & cambelt
definatly check the boot haha. checked mine yesterday only to see my drive through a big hole where one of the drainage holes used to be.
