mk5 rear seat removal?
does anyone know how to get the back rest of ???
  • Views 3k
bump any one !!
If you pull the two tabs to drop the back rest forwards then look on each side theres a hinge you need a flat blade screw driver and push the part that's holding the back rest hinge in! Do it on both sides, Should release it! If it's a split back rest there's 3 torx or Allen bolts to undo and there you go!
hard to explain, pull up the lower bench via the front of them, folded down the seats using the pull up pins next to either side head rests, then on either side of the back rest there on two clips that slide back sort of, then in the middle there are two clips that you kinda have to force out with a screw driver. then they should just pull out, something like that
yep and to put em back in just push em in and they clamp shut again
I carpeted my back with the seat out. It wasnt all that bad. If you put down some cushion it would look even better.
