camber/caster ajustable tubuler lower arms
as title says realy..would anyone be interested in a set of these? basicly they are tubular lower arms with fully ajustable rose jointed ends, you will be able to adjust camber ect.. obviously these are not polo ones the pics are just to give you an idea of what they look like ect..
the advantages of having these arms are that you have to replace the rose joints very rarly aslong as there kept clean(hose road salt/grit off) unlike standard bushes, will improve handling, acceleration and braking tenfold.
the rose joints static radial load on the rose joints are 83kn which is the equivilent to just over 8tonnes, so they are extremely strong so no chance of snapping, bending or popping the ball out as they will not be put under anywhere near that amount off pressure.
they will be powder coated in whatever colour you like!
Tubular Lower Arms Pics. CLICK
Thanks Liam
  • Views 385
Hi possibly intrested in these what polo would these be for and how much would they cost. also who makes these?
Cheers phil
Dependant on price and fitment would also be interested in a pair myself (for MK2) I know my current ones need replacing ideally anyway, so would kill 2 birds with one stone if I could use these to adjust camber on aswell
I'm presuming these are only going to be for mk4 and newer polos since the old ones don't have anywhere to mount a wishbone without fitting a subframe (see the PPP section for what I mean).
Can you post up what cars these are for mate?
Cheers phil
they would be around the 350 mark for a set and for the 6n and 6n2,
without looking at a mk1,2,3 setup on the front mate i couldn't say how much ect ... if you have a few pics of the front wheel arch area so i can get a look at the setup on the older ones i will get back to you.
cheers
yes mate sorry there for 6n, 6n2 atm ill be looking into the setup on the older ones
cheers
after a few days of looking into the set up on the older polo's it is possible but it means doing the same as PPP does! as i dont want to upset anyone these arms will be only available for 6n and the 6n2's, i will also be making strut braces front, rear and front lower for the 6n and 6n2, no pictures availible yet but will post some up when the final designs are done. i also offer aluminium and stainless steel welding (TIG) all done to a very high standard, i can basicly make anything you want on-offs anything just pm me.
last little question to anyone who knows is there a traders fee ?
thanks liam
there is a trader's fee yeah, various options. Give Kam (username: heartagram) a PM as I think he sorts it out.
thanks mate :thumbsup:
