how to put fin arial on?
I bought a fin arial today from halfords, but i have no idea how to install it, my polo is a 57 plate, and the standard arial i have atm is like suctioned on, i read about it, and apparently you have to push down on it and pull it up really fast, i tired it but its just not working.
could someone please help me out.
cheers,
lewis.
Edited by Green_Crayon
  • Views 1.4k
tried unscrewing it lol?
lol how i cant see any screws?
you've bought a whole aerial unit? or just the bit that screws into the base?
if you've bought the whole thing, you'll need to unscrew the base from the car, which means undoing the headlining trim at the back, then unbolting the base.
:lol:
The aerial unscrews from the base.
lol. Open your boot. Then look up on your roof lining will be a plastic trim close the the end of the roof. Pull off the trim and then gently pull your roof lining down. If you do it to hard you will crease the roof lining. Once you have done this look up and you will see a nut. should be roughly a 17mm nut. just un screw that and unplug the pull it off from the outside. :)
Think the information i have givien should be the same on your 9n3 as it is on my valver.
hope this helps.
Kuszpit :)
cheers people LOL i just did it, it was just a plastic clip i needed to undue, cheers for the help everyone :D
lewis.
