6n2 tdi
Guys,
I am coming back to a polo after owning a 6n some years ago.
I am after a 1.4tdi for fuel efficiency.
Having never owned a 6n2 or diesel before can you tell me what to look out for?
In my 6n the electric window used to play up, is this a simple fix with a new regulator?
I know what I'm looking for body wise but any heads up will be great.
Also what mileage can these engines doe if well maintained.
Thanks all
  • Replies 8
  • Views 1.3k
I bought a 51 plate 1.4TDI about 4 wks ago, awesome little car. Really good on fuel and it pulls well in every gear. Make sure you buy one registered after March 2001 otherwise you will pay higher road tax, mine is £35 for 12 mths because it was registered in Nov 2001
Mileage wise I would have hoped you could see 200k+
Engine's fairly bulletproof and will go for ages if looked after, as most will be over 60k make sure the cambelts been done and make sure the clutch isn't slipping as that's an expensive job due to the fact you have to replace the dual mass flywheel at the same time
Other than that, not much to look for, shouldn't be any rust but just give the rear arches the once over
Cool
Cheers for that, Il hopefully get one this week. Cheers
6n2 tdi's come in two specs S or SE. I would go for an SE as its got a much better spec such as alloy wheels, fog light etc.
Make sure its had the camblet and water pump changed at 60k or 6 years as its expensive.
Also check out the gearbox in this i mean that some had problems with selecting 3rd, i've seen this a few times now on both the polo and arosa tdi.
Engines should do 200k easy my sister in law has done over 200k in her 1.4tdi.
Its a terrific little engine, make sure you chip it cos you and get it up to about 110 bhp easily, and if you add a new tailpipe and filter then you can get get about 125bhp no sweat, and great Mpg! My mate's got an arosa tdi, same motor and that goes like a rocket! smart buy! make sure you get a high spec one with air con alloys etc and you're onto a winner
Roughly how much for a chip?
You're better off remapping the ecu as a chip just up's the fueling and does hardly anything for the flat spots, remaps are usually about £300
As for 125bhp with chip, tailpipe and filter, I severely doubt that my friend, I'm running 110 with the map and a good friend of mine has a lupo with the same engine only decat'd with a performance panel filter (don't bother with cones it won't do anything for performance as diesels don't fuel by the position of a throttle plate) and he's running about 115 (proven)
To get 125, you have to fiddle with the engine internals and tbh, that's far too much mucking about for 10bhp...
True 125 does seem a bit farfetched - liam does bullshit a fair amount! Definitely a quick car though....
