Removing and painting rear VW badge on 6n polo?!?!?!
how do you do it, is there anything special you need to use?
  • Views 992
Hi mate,
This type of question comes up alot so check out the search tab.
I just used a trim tool for interiors to get it off. (its like a plastic screw driver) Or you can use a screw driver with a cloth round it.
Put behind the rubber of the badge and pretty much wiggle till it drops off. As for spraying it. rub down all the chrome, then primer it then add the colour wanted.
Kuszpit :)
thankyou mate will be doing this tonight.
