6n2 dash and steering wheel
i'm trying to get the steering wheel off in my 6n2 but can't get the airbag off and its annoying me now, also how do you remove the clocks these
  • Views 944
I imagine for the airbag, there will be 2 torx peices in the back of the steering wheel, there are in a 6n anyway. But iirc you need to disconnect the battery for half an hour befoe you disconnect the airbag, or it can go off. Or so iv heard...
it sounds like clips as you can here them springing about if you know what i mean
It wont be clips, as it needs to be securely fastened to the steering wheel. As in an accident it would explode with such force it would just fly away from the wheel if it wasnt securely attached.
It is clips but fuck me they are on well as i had troble geting them of when i was fitting it to a 6n you need a flat screw driver to slot in the holes in the back and you need to puch the clips of but takes time as you can only do it 1 way
