Improving Wiper Action
When i put the wipers on, whether it be road spray, light or heavy rain they always judder across the screen which leaves lines where its wiped and the motion and noise is generally annoying!
The screen is always clean (I'm quite meticulous about it) the blades are also new and clean and I've lubricated all the joints and pivots on the whole system as well as making sure all the bolts were tightened to a point where they dont move much but are free enough for the wiper action. Also the battery is nice and charged and it doesnt make a difference if i turn everything on (fans, heated rear screen, full beam etc) or have nothing on. they slow down slightly with other electrics on but still judder.
Is there anything else i can do to improve it? fit another more powerful volkswagen motor? and are there any that fit straight on? upgrade the wiring/earth?
Any other advice is appreciated :)
Matt
  • Replies 10
  • Views 1.7k
I've found if I put cheap blades this can happen. Also what window cleaner are you using?
i have used bosch wipers and now using goodyear ones, dno how good they are in comparison to others? also i use autoglym glass polish and then rain-ex glass cleaner and rain repeller stuff!
the best wiper blades by far are Tescos belive it or not, the premium 6 quid ones. they are heavier and form better to the glass. way better than bosch. I've had them quite a while, and not streaked once.
also, make sure the wind deflectors on the blades are the right way around, so at speed (about over 40mph) they push the wipers to the screen, not lift them off causing streaking and jumping.
I dont have wind deflector ones bro! just bog standard wiper blades! might try the tesco ones next then man!
if the blades are good and the screen is clean...try giving the arm a gentle twist to alter the angle that they meet the screen
i had this problem with my mk1 golf so put the mk2 golf motors innards into my mk1 golfs motor casing. tada working wipers, not fast ones mind but working haha.
not sure if itll working with a mk3 motors innards in a mk2s, or if they are directly interchangable, I've owned both but never really had a good look
get retrofit aero wipers, job done no faffing
I've always used Bosch blades,always the standard ones with no spoiler,only ever with a detergent-cleaned screen (no fancy junk,but no jet-wash wax either) and never had a problem. And that despite having to bend two parts of the mechanism this year to fit a taller battery in.
I dont think the answer is in trendy aero stuff,there's clearly something wrong with your wiper system somewhere. I'm going for the spring rate on the arms. Maybe the springs are getting tired,i dunno. You can bend the arms in or out a little to alter it,but getting another pair would be best.
The other likelys are worn joints in the mechanism arms,or weak motor. Wiper arms may be available new,but finding a scrap early '90s car would give you all you need for pennies.
Also note Steveo's point - if the wiper body isn't true to the screen,it'll judder. Usually only in one direction though. This is true also of blades rarely used for months - so the dry summer could've memory'd the blades and caused them to sit untrue during drag.
I've only known this to cause judder in one direction though.
I seem to have cured it! was trying to get the wiper motor off to have a better look at it and couldnt for the life of me get the nut to the motorspindle undone!
anyway saw a sticker and peeled it back and it revealed a captive nut and what i guess is a screw, sprayed a load of quality silicone lubricant all round it and in it and it seems to have gone into the motor and eased it up and made it work easier. yesterday i put the wipers on and taddaaa! smoooth wiper action! :D
result!
this will probably be an obvious question, but i managed to have broke my wiper stork, leaving my blades up, been waitig to repair it, now just need to find the fuse? if even is one to check and/or replace? i can't seem to find anything anywhere though.
