Central Locking Problem
Hi guys, I've got a problem with my central locking on my 6n2 gti. when i press the remote to lock the doors it does not work, the lights flash to indicate that the alarm has been set but the door pins dont go down. Also there is no noise from the pump. I have changed the fob batterys, checked the fuses and the only thing i have not checked is the relay if there is one, if that is the case then where will i find this relay switch thing? any ideas guys?
cheers
cj
  • Views 697
try another pump? located behind the 1st aid kit...
