Will superlites fit a mk3 polo ok?
Hi guys,
as above really, the offset is 4x101.6 (mini fitment) where as obviously the polo is 4x100. So will i need spigot rings and wobble bolts or will i get away with it?
Cheers, Dan
Edited by duckdown_hoodrat
You will need spigot rings and wobble bolts to esure a decent fit :thumbsup:
Yeah but it will look silly as the front wheels will poke out a fair bit, an the rears will be tucked! Unless you flare the fronts that is... 8-)
Edited by Iscariot
i have got wobble bolts and spigot rings if your interested?
depends which width you fit. 6js up front just about line up with the edge of the wheel arch
