R Plate Polo Drivers footwell full of water..........
Sorry if this is the wrong section but I couldnt find anywhere else to post this?
Just bought myself an R plate polo 1.4 16v, got it home and started to give it a nice clean then noticed the drivers side is full of water and I mean dripping wet! So I stripped out the whole interior to get it dry but am struggling to find where the water is coming in it seems to be coming in near the main door seal but this looks ok?
If anyone has any advice on common leak problems with these I would appreciate your knowledge.
Dave
check your door seals...also check under the plastic panel beneath the wiper blades, if this is full of leaves and crap then the water cant drain and will leak into the car
common problem
perhaps the previous owner had a bladder weakness. :lol:
My car had same problem, turns out seal on windscreen was gone on. A new windscreen fixed it. hope this helps.
