Snow foam and lance
As roads are getting crappy I`m wanting to loosen muck before I wash. Got a low power Karcher pressure hose and was going to use there replacement end for running the snow foam through, are there any alternatives people have used and what is the best snow foam to use?????
  • Replies 10
  • Views 1.5k
TBH Dude, that's what I use for my car the Karcher foam lance and although it's not adjustable like some of them it seems to do the job very well :) As for stuff to use through it I just tend to use cheapo shampoo like the halfords own or something. A quick pic using it on my BM..
Cheaper than the likes of the Gilmour ones etc too :)
i get free use of all the cleaning products at work. we deliver hire cars for insurance companies. we use autosmart products. i jet my car off with water and then cover it with active xl. leave it for a couple of minutes and then jet it off. no brush or sponge required. we also have excellent alloy cleaner which is basically semi neat acid.
Problem with those is that theres always too much water and most of the foam washes off before it can get to work. it should look like this:
Nice heavy and sticky foam that will lift off dirt.
Edited by Cymro
I know yer, that's a gilmour isn't it? It probably doesn't help that i'm not using proper snowfoam either though lol! But I wouldn't go as far as saying i'm a full on detailer so the difference between a £17 Karcher foamer or a £50+ Gilmour or similar gun is quite significant for what I use a foam gun for. In saying that, i'm not saying the other brands arn't worth the extra as you can easily see the difference between mine and your guns :)
Edited by griffo20022
With the snow foam one it should look like God has blown his load all over your car.
It allows the dirt to be lifted off the car alot easier than one with alot of water. The ones with extra water just require more work than the "proper" one.
Its all about time and finish, better finish in less time is why the snow foam was invented. You could spend more time to get the same results, but for detialers and valets time is money.
Either way, any type of shampoo in the foaming lance will give a good coverage, may need a bit of a rub with a sponge though
So is it the lance that makes the difference? Should I buy a Gilmore and what foam are people using?
Tbh defo go for the better items. I own my own detailing business which i started when i left school. I went out and bought a Karcher power washer that cost me £349.99. I then bought a snow foam lance (cant remember the name) but that cost me £59.99 and i use meguiars shampoo made just for snow foam lances.
Heres a quick pic of it on my valver u can really tell the difference between the cheaper ones.
Kuszpit :)
can remember the name of mine but it was £70 for the lance, a 1litre bottle to connect to it and 1 gallon of snow foam
get a nice thick foam and does a really good job
this is it on a black Audi A4
and a purple lupo
result
Now i like that.
If you saw it in person you probably wouldn't!
It's inside at UD every year.
