DE BADGING Mk4 Polo 1.0l HELP!
Is the polo badge on the rear just stuck on with glue
or does it have pins going into the boot ?
just wanna know if its just a case of pulling off the badge and polishing up the surrounding area
so that you cannot tell it had a badge, or whether I'm gonna need to fill up holes after and have them sprayed over ?
can anyone helpppp ?
  • Views 1k
There just stuck on with a glue. When you remove it, there might be some glue residue, but that comes of pretty easy with some warm soapy water.
easy! =D
Is this the same a th mk5 6n2 ?
Yep :)
Jut use warm water to get the glue off, and a hairdryer/piece of wire to get the bade off :thumbsup:
i did mine useing wd40 let it dry in and then some more and can slide and pull the badge off and then clean it up, it looks a lot better =D
there is this stuff they sell in halfrads called sticky stuff remover and that does a good job i just sprayed it over the badge and it allmost fell off and it has many other use's aswell :-D
