£300 MK3 Polo
I got a MK3 Polo Boulevard 1.05 off ebay. 300 bucks. It had a nice long MOT so i thought ide give it a go.
Been running it now for a couple of weeks relatively problem free (exhaust fell off a few times maybe three) and have some questions for you all:
Are the heaters really that bad? No heat at all comes out of the main vents regardless of what you tell it to do only ever coming out of the windshield ones.
The back wiper is the most annoying thing about the car once you've pressed the lever in it will not stop. Does anyone know how to stop it?
The back window ALWAYS steams up does anyone else have this problem or does my car have water hiding inside it. Or do you all just leave the heating element on permanently.
Sometimes when you try to start the car up the starter motor doesnt seem to be connected at all to the engine it just spins freely but on a second try all will be well again. Is mine knackered?
Apart from that it seems to be quite a decent wee car.
Quite fancy gettin a set of coilys off ebay for 135 quid has anyone fitted them to their MK3 and are they hard to fit as I've heard you have to cut stuff off - something to do with the hub? I thought about just springs but one of the dampers is kaput it was mentioned as an advisory in the MOT.
Also the two speakers in the dash are shit can you fit 10cm ones in the space?
I've fitted a MK2 golf gearknob to it because the other one was way too low and seems to be a much easier car to drive now with a good driving position. Also got an induction kit from a mate for nothing so did a bodge job and removed the air filter out of the frying pan under the bonnet and now have it on the wee plastic pipe where the air enters the induction box. Quite a decent fit didnt make much if any difference though. I put red tape in all the recesses in the bumper £2.50 for 9m of red tape from Halfrauds and then hammerited the VW badge black. They look pretty good almost standard dont they?
Quite interested in gettin some G60/passat wheels from VW apparently they're only 40 quid each or something brand new will they fit in standard arches and if so with what size tyres?
Hope these can cars go forever.
Tam
  • Replies 20
  • Views 1.7k
Okay bits i know of
The heater vents, NO Mk3 has hot air coming through I'm afraid, underneeth is your best
And the starter motor I've got a mate who has it, Ill let someone elaborate on this
And coilies will cost far more than £135 more like £400 as they have to be custom made
What your looking as is a springs and a shock that cant be adgusted up front, but can o0n the rear
10Cm speakers fit yes :)
With the air filter, to get anything worthe out of it youll need a 1.8GTI Mk3 Golf inatke elbow, this replaces teh Big circle airbox and the fiter attaches to that
Luke
The G60 steels are 15" and you'll need stretched 165/50 tyres a pressume if your going real low.
Or try 195/45 tyres
With the rear wiper, just push the stalk again and it'll stop :).
Tam
this may sound silly but with the induction kit .. the more air u have coming into the engine the more that needs to get out .... try a bigger bore exgaust might make a lil bit of a diff lol
Or try 195/45 tyres
Why would hey need to be stretched? The steels are only 6'' wide, with a standard -35 et, so they wont be poking out of the arches.
If you mean purely for cosmetics, then stretch on 6" looks gash anyway
remove the rear wiper and replace with a grommet.
Bigger bore exhaust won't do nowt, apart from maybe a slight loss in backpressure. 4-2-1 Manifold would be better for an un-tuned engine.
my new polo breadvan was £300 off ebay as well! lol there must be a few of them on there at the moment! :)
what size tyres would be ok with G60 steels (not stretched)? quite fancy a set of them myself.....
lol it took me ages to realise that as well on mine. its because when you push it again you look at the r/w mirror to see if its stopped and when you push it it goes again lol so you keep doing it and turning it off and on
the rear wiper is so annoying. i never leave it on i just press it once the press it again to stop and it clears it. now it only goes to one side but doesn't go back on its own so its now in the center of the window lol
the rear wiper makes the most annoying noise in the world
and the rear heater for the window is also a pile of bollocks
the elements always have breaks in them
which can be fixed with some stuff from halfords but i can't remember what itis
they fit if you cut the plastic around the holes bigger with a blade, they won't fit straight in.
the starter motor whirring freely on the first go.. probably means the solenoid is fucked and not engaging the motor to the flywheel.
basically, just find a new/reconditioned starter motor. or any unit from a scrappy would do really. the solenoid is part of the starter motor unit, so just replace the whole thing.
takes about 10 minutes to do, once you can reach the dam thing! ;)
Thanks for all your replies guys. I've always been too impatient to try figure out a way to stop the wiper and just go mental with the stalk till it eventually stops.
Ill have a look into the solenoid/starter motor thing though cheers for that.
And about manifolds and exhausts I'm surprised if anyone even makes any for the 1.05 engine of that age they cant sell to many of them surely. it wouldnt be worth it unless it was really cheap either ide be best just getting a GT.
I've heard of people using G40 exhausts though what are the advantages of these over the standard ones?
They seem to be pretty bullet proof otherwise. My mum gets raging when her shitty and much newer Fiat wont start in the cold mornings just now and mine has nae bother (if the starter motor has a good day mind).
Also does the car actually go round corners at all with wider lower profile tyres and lowered suspension? or does it still understeer like a bitch?
lowered with wide wheels and small profiles handles amazing mate. if you were gonna get 13 inch wheels id recommend yoko a359s. the standard wheels are shockingly bad but iv out-cornered quite a few newer cars with wider wheels
For hot air through the vents, see here.
Anyone mind telling me how to set the timer on the wipers? I stumbled across it the other night... never realised it was there lmfao. Was quite impressed the first time I turned it on lol :D.
thanx :)
Yeah if you want more power just convert it to GT. An exhaust mani is gonna cost you a good 150-200 quid, which will give you what 3bhp more? I've seen GT conversions going on here for about 250 for a good one, an with that you're going to get an extra 30bhp... so makes sense really!
Haha it must've had an intermittent wiper module from a golf at some point, they don't come as standard (unless I'm being stupid an they do?). I've got one in mine.
It only works on slow setting; but what you do is turn the wipers on then off quickly, then when you want them to come on again flick the stalk down again an leave them on. Now they should be set to the amount of time between when you had them on and off (If that makes sense! I'm not great at explaining hah).
